Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 02-25-2004, 05:12 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
1999 Ford F-250
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
Looking for the weekend!
Looks like it will be a great weekend to get out and do some off roading and outdoors projects!
Well I had me truck on some nasty back roads today. The wet weather and freezing we had was't nice to the back roads! They were very rough and ruted.
Up date on the intake/carb mods:
At low speeds and heavy throttle, it stumbles some.
I need to tweek some more!
I am having trouble getting it to kick down off high idle. I think it is running too cold.
  #2 (permalink)
Old 02-26-2004, 04:12 AM
fitter565's Avatar
fitter565 fitter565 is offline
Garage is empty, add now
fitter565 is starting off with a positive reputation.
5_labs, 1st, When the truck stumbles do you get black smoke from the exhaust? You might have your floats set a little high. 2nd, If your truck has an elec choke, you can ajust it back a little and that will fix the high idle problem. There should be 3 screws on the cover of the choke thermostat. If you look real close there should be index lines on the cover. Loosen the screws and turn the cover back untill the choke opens sooner. This should take care of the problem and let the high idle kick off.
Fitter
__________________
2005 Explorer Sport Trac XLT Premium
2002 Escape XLT 4x4 3.0 v6 (Wifes ride)
Support FTE
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
