Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-25-2004, 05:01 PM
tastyklair is starting off with a positive reputation.
grinding you own valve seats
I'mm Looking at doing my own valve job. The guides are good and actually the seats and valves aren't bad, but I'm porting the heads and will probably need to reface the seats afterward. I have an inexpensive kit available. Anybody ever do their own? Any thoughts?
__________________
79 f150 4x4
408,Crane 941
Scorpion roller rockers
Performer intake and carb.
hmm, 434 stroker?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-25-2004, 05:11 PM
Capone is starting off with a positive reputation.
One word for you.....
Concentricity.....
oh and did you cut back the rear face of the valve heads? this can also aid in flow....(it is kind of like giving your valve heads a 3 angle valve job on the port side of the valve)
__________________
88 E. Bauer Bronco 5.8
List Mod's in Gallery
  #3 (permalink)
Old 02-25-2004, 05:30 PM
explain
I looked that big word up so I know what it means, but what are you trying to say?
__________________
79 f150 4x4
408,Crane 941
hmm, 434 stroker?
  #4 (permalink)
Old 02-25-2004, 06:20 PM
Ecuri is gaining momentum as a positive member of FTE.
You can hand lap them. Look it up in your Clymer or whatever. It is practically free. Put some varsol down the ports overnight and see it they leak.
He is trying to say the valves should seal in whatever location they land. Two( or more) perfect circles, the seat and the valve face. GL
__________________
78 F150 408 4v valves/C6
77 F250 390/NP435
99 Explorer daily driver
  #5 (permalink)
Old 02-26-2004, 08:15 AM
tomw is starting off with a positive reputation.
If you lap the valves, make sure to keep them in the same cylinder. Pull or push the valve about 1/4" up from the seat, and try to rock the valve around. If you get much motion, your valve guides may be too loose. Lapping using compound you can get valves to seat so that you have a shiny surface in the valve and seat that is the same width all the way around the valve. If you do not get an even 'shiny', then the valve is not matching with the valve seat... as noted in the fancy word, concentric.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #6 (permalink)
Old 02-26-2004, 10:14 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
If you polish the chambers you can drop a couple of old valves in there while you do it to protect the seats. If too much damage is done to the seat the might require inserts to correct it.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
