F-150 5.4L oil capacity? - Ford Truck Enthusiasts Forums
Old 02-25-2004, 02:06 PM
ghiaman46 ghiaman46 is offline
ghiaman46 is starting off with a positive reputation.
New to the forum. My son just bought 2000 F-150 4x4 with 5.4L. He wants to change the oil but has no owners manual. We have 2 conflicting sources for number of quarts of engine oil needed with filter change. Chilton manual says 7 quarts, and owners manual for friend's 2001 F-150 says 6 quarts for all engines. I doubt Ford changed oil pans between 2000 and 2001 but ....
Old 02-25-2004, 02:56 PM
route61 route61 is offline
route61 is starting off with a positive reputation.
My 2002 F150 Lariat Manual states ALL Engines (6 quarts)
includes filter change
Old 02-25-2004, 02:59 PM
Firefighter Ford Firefighter Ford is offline
Firefighter Ford is starting off with a positive reputation.
oil
If you have the oil filter up in front of the driver side tire then you take 7 quarts. IF it is under the truck then only 6.
Old 02-25-2004, 03:40 PM
grizz5675 grizz5675 is offline
grizz5675 is starting off with a positive reputation.
in my manual for the 2001 5.4 triton motor it says its a 6 quart system
Old 02-25-2004, 05:25 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
6 qts is recommended by Ford. On most 5.4's when you change the oil and filter with 6qts, it will show 1/2 qt low. This is normal. I usually run 6 1/2qts myself.
Jimmy
Old 02-25-2004, 05:26 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
The manual says 6 qts. , however the line on the dip stick will not be up to the top. This is not a problem because it is still in the "full" area. The last time I took mine to Wal-Mart and they put 7 qts. , probably just to charge me more?!
Old 02-25-2004, 05:34 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
If you would like to see an online owner's manual, go to the Ford Motor Co. website, www.fordvehicles.com and register for "My Ford". Once you log in, look for a section that says "Resources and References" Click it, and you find a link for the Owner's Guide.
Old 02-25-2004, 06:03 PM
scott_parker scott_parker is offline
scott_parker is starting off with a positive reputation.
Filter up front drivers side under bumper = 6.5 quarts
Filter on drivers side up on side of motor = 6.0 quarts usually
Old 02-25-2004, 06:11 PM
LxMan1's Avatar
Mine filter is on the engine block and it takes 6-1/2qts to reach full.
Old 02-26-2004, 12:39 AM
CPerry's Avatar
CPerry CPerry is offline
CPerry is starting off with a positive reputation.
I assume the oil pan is the same size on the 4.6. My filter is under the bumper and takes 7 quarts to reach the top of the line on the dipstick.
Old 02-26-2004, 08:26 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
If you fill the truck with 6qts and do the required filter change, run it for a few minutes. Let it sit for a little while and check the level, then fill to put the oil level in the full range if necessary. Then you'll know how many qts so you don't over or under fill it next time.
-Kerry
Old 05-29-2011, 12:29 PM
moses31984 moses31984 is offline
moses31984 is starting off with a positive reputation.
5.4l V8 oil capacity
if the filter is on the front of the block right above the axle it is 7 qts, on the stick it will read half a qt low but that is normal for fords, all ford engines have a half qt baffle and it can take anywhere from half an hour to 6 hours for that half qt to reach the pan, weather your ford says 5 6 or 7 qts dont add that half qt just cause it reads low, you are actually overfilling the oil if you do, i worked at a ford dealership for 2 years and managed valvoline for 3 years
Old 05-29-2011, 05:20 PM
FordManDan30 FordManDan30 is offline
FordManDan30 is starting off with a positive reputation.
What can happen if quick lube puts 7qts in and it only needs 6? Can there be any real damage done?
Oil Capacity for 2004 Expedition 5.4 4WD Cornell1 1997-2006 Expedition & Navigator 13 09-26-2012 09:36 AM
Oil Change question tk3445 Ranger & B-Series 8 06-13-2006 03:54 PM
352 oil capacity jd_sylvia 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-17-2006 12:08 PM
How many quarts of oil xspeedyx 1997 - 2003 F150 8 11-21-2005 10:12 AM
Number of Quarts koziol41 Oil & Lubrication 5 11-17-2003 09:45 PM
Tags
00, 04, 05, 08, 2004, 2006, 46l, 54, aztek, capacity, compacity, f150, ford, oil, quarts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
