Ranger 3.0 Engine Noise - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-25-2004, 10:12 AM
russ657399 russ657399 is offline
russ657399 is starting off with a positive reputation.
Question Ranger 3.0 Engine Noise
HELLO, I'M NEW HERE.
LOOKED THROUGH THE ENTIRE SITE FOR SOMEONE WITH MY
PROBLEM AND FOUND NONE.
MY 1999 RANGER 2WD 3.0 HAS A NOISE COMING FROM
NEAR PASSENGER SIDE VALVE COVER, VERY DRY HARSH
SQUEAL. SERP AND PULLEY ARE NEW.
I HAVE 162,000 MILES ON THIS TRUCK WITH NO
SERIOUS PROBLEMS - YET
ANYONE KNOW WHAT THIS COULD BE?
Old 02-25-2004, 12:49 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave Flexfuel-Dave is offline
Flexfuel-Dave is gaining momentum as a positive member of FTE.
Re: Ranger 3.0 Engine Noise
Sorry to hear about your aggravation Russ. Does the sound change when turning your steering wheel? Does the sound change when your headlights are turned on?
One way to isolate the source is to remove your accessory belts then run the motor for a short time. While it's running, try to see if the noise has gone away or still is present.
If itís still there try to detect the exact location.
If it has gone away itís likely accessory related. Reconnect one belt at a time (and run the engine) to help narrow down which accessory could be the bugger.
Old 02-25-2004, 12:53 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Re: Re: Ranger 3.0 Engine Noise
There is only one belt with a serpentine!!!
Russ, there are 2 pulleys that will squeal, an idler pulley, and a tensioner pulley, did you have both replaced????
Old 02-25-2004, 02:28 PM
THANKS FOR THE REPLY.
THE TOP PULLEY JUST ABOVE THE FAN AND THE BELT
WAS REPLACED. I WILL CHECK THE OTHER PULLEY.
IF THIS NOISE ISNT COMING FROM UNDER THAT VALVE
COVER MY EARS ARE GOING.
I WAS AFRAID OF A DRY ROCKER OR CAM (IF THERES
ONE ON EACH HEAD)
THANKS AGAIN,
RUSS
Old 02-25-2004, 02:36 PM
ONE ON EACH HEAD)
THANKS AGAIN,
RUSS
The 3.0L is a pushrod engine, there is only one cam, and it's in the block....another thing that is known for making a noise is the
IAC valve, which is located on the throttle body.....
Old 02-26-2004, 08:46 AM
Bob,
you may have nailed it about the IAC valve,
of course now its being quiet, but I checked
out IAC valves in general and my truck has
shown some other IAC symptoms intermittently;
not starting on first crank, then a 300-400 rpm
idle and stall. theres also some variation in the
idle speed so I am going to get a new valve.
thanks again
Russ
Old 02-26-2004, 09:33 PM
mikeh98 mikeh98 is offline
mikeh98 is starting off with a positive reputation.
Only 162k and you're still on your first IAC? Seriously, I have 194k on my '98 4.0L supercab and am on my third. First change was due to the dreaded "squeal" and the second was due to the squeal and idle problems. My wife's 2001 Explorer with 4.0L doesn't squeal but sometimes will be a hard starter. A sharp rap with a block of wood on the manifold next to the IAC clears up the problem for quite awhile. Will replace it when the weather is better.
Ford must have had a bad batch of these.
Good luck.
Old 02-27-2004, 09:59 AM
mike,
I think it may have been replaced by ford at about 90k
along with mass air sensor, egr. a few things "went"
at that time, and I had to split the cost with ford because
not all was covered under my extended warranty.
Im going to get a new one now.
thanks, russ
2007 ranger 3.0 Ranger glen Ranger & B-Series 4 01-29-2015 07:58 PM
problems with my ranger frogmanc1 New Member Introductions 2 10-14-2013 02:19 PM
2000 ford ranger engine swap ranger repair man Ranger & B-Series 1 04-05-2011 01:41 PM
Timing Chain or Belt HaroldCallahan 4 Cylinder Engines 4 10-08-2008 01:19 PM
rattling/knocking noise from manual tranny slvr00gt Ranger & B-Series 7 01-28-2008 10:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
