Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-25-2004, 01:45 AM
jasonmartin206's Avatar
jasonmartin206 is starting off with a positive reputation.
Carb adjusting question
How do I adjust a 2bbl carb?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-25-2004, 06:46 AM
RichardMaerz69 is starting off with a positive reputation.
what adjustments are you looking for.
__________________
Richard Maerz
  #3 (permalink)
Old 02-25-2004, 09:40 AM
I'm not sure, someone told me I needed my carb adjusted cause it runs rough.
  #4 (permalink)
Old 02-25-2004, 11:34 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
You should have an idle mixture adjustment screw for each side. Slowly turn them in/out to obtain the highest idle speed on a warmed up engine. Go back and forth a few times and listen closely for best idle quality.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #5 (permalink)
Old 02-25-2004, 03:22 PM
2003 7.3TD 4x4 F350C is starting off with a positive reputation.
First I would buy a good quality carb cleaner. Pinch off the fuel line at the intake side of fuel pump with needlenose vicegrips. spray carb cleaner in to fuel bowl overflow spout (the spout is cut on an angle and is tall next to air cleaner stud.) let engine run on cleaner till it dies then fill float bowl with cleaner and let sit hour or so. then restart with fuel line unpinched.
Cleaner will get in to most all passages and clean varnish from passages.
Quick and cheep then adjust carb if needed.
PS most carbs have plugs that need to be removed to adjust air/fuel mixture.
Rich
  #6 (permalink)
Old 02-25-2004, 08:11 PM
what plug and where on the carb?
  #7 (permalink)
Old 02-26-2004, 05:38 AM
they are on the bottom front where your idel mixture screws are,the caps are usually put on at the factory after it's set,you might have to pull your carb of if you have them,but take a good look first you don't want to take it of if you don't have to,somedodie here might have a way to get them out without reamoving the carb.
__________________
Richard Maerz
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
