Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-24-2004, 05:25 PM
Shinoda's Avatar
Shinoda is starting off with a positive reputation.
300 I-6 to 302HO
OK, I have a question, I have an 88 F-250 with the 300 I-6 and the C6, I also own an 87 Mustang GT and am planning on swapping on Explorer Heads, Intake an Throttle body + an E-CAM for some more power out of it. Well, I do very little if ANY towing with my truck, has 4.11's in the rear-end though, because it used to belong to my grandfather who towed boats all the time with it. I'm considering putting my old HO heads, Intake and Cam from my Mustang on the Explorer 302 block, in essence, making a 302HO out of it except the Explorer block has Flat-Top pneumatic Pistons, so no NOS, S/C or Turbo, but that's really irrelevant. How much work is it to swap a 302HO into my truck and do I need to change the bell housing or anything or does it bolt right up to where the 300 I-6 is? Any suggestions, comments would be greatly appreciated.
Also, on a completely different note, what size bolts/plugs go where the fresh-air pipe goes into the head? mine are leaking like a bugger at the moment and makes using the heater a fumy experience, and of course, its ticking a lot too.
__________________
1987 Mustang GT Pro-Prtd GT40s TFS R Intake TFS Stg1 1.7RRs
1988 F-250 Custom was 300 I6 now 302HO
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-26-2004, 03:42 PM
steell is starting off with a positive reputation.
I think you mean hyperautenic (sp) pistone
HO motor used forged piston up through 92, but in 93 it switched to the hyper pistons also, and they are flatop pistons as well.
Bellhousings are interchangable between the 4.9L six and the 302, although I think the motor mount locations on the frame are different and will need to be changed.
  #3 (permalink)
Old 02-26-2004, 04:18 PM
Shinoda's Avatar
Awesome! Yeah, that's the word I was looking for, hyperneutenic or whatever.
Thanks for the info.
__________________
  #4 (permalink)
Old 02-26-2004, 08:33 PM
78fordman's Avatar
78fordman is starting off with a positive reputation.
instead of puting the money into a 302, why don;t you sup up the six, or a truck, the 6 will out pull a 302 anyday. If you are looking for like a rodrod truck, the 302 is a better choice. As for the conversion, mounts will have to change, as for bellhousings, the 351/302/300 had the same. I do not know the weight difference between a 6 and a 302, but you might have to get heavier front springs. Also i am pretty sure there are difference sensor hookups and such, plus you will need a 302 PCM mod which will work with a c-6. Wiring harness might have to be changed out for one for a 302.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #5 (permalink)
Old 02-26-2004, 11:09 PM
Shinoda's Avatar
I'm getting the entire setup out of an Explorer, I'm not "putting any money out" for this motor, as I'm buying it for the heads and intake anyways, so I'm just going to have it kicking around. The HO will smoke my I-6 in terms of HP, not low-end, no, but HP, definitely, and since I don't tow with it, I think its probably a better choice. Converting the Mustang to Mass-Air as well, so will have Mustang Computer for the truck too.
__________________
  #6 (permalink)
Old 02-27-2004, 01:27 AM
AlfredB1979 is starting off with a positive reputation.
For the work needed, you will wonder why you did not go the 351 route.
ESPECIALLY in an F250!
HO version or not, the small v8 is a step BACK compared to the 300!
  #7 (permalink)
Old 02-27-2004, 02:05 AM
Shinoda's Avatar
It has like 50HP on the I-6, how is that a step back, even if it is further up the rev range?
__________________
  #8 (permalink)
Old 02-27-2004, 02:09 AM
Shinoda's Avatar
Its really not that much work either, I'm not going to try and do it in one day or anything, I will do the Mustang first, heads, intake and Cam on it, then put together the other motor out of the old Mustang parts and when I have some more time, start on that and work on it in my spare time while I'm driving the Mustang. Should be fun actually I'm not going to throw out the I-6 or anything, might build it up too and use it later, but for now the 302HO is some quick drop-in power that is easy to get parts for.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
