Which motor oil weight do you use on a 351? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 02-24-2004, 05:22 PM
cueman cueman is offline
cueman is starting off with a positive reputation.
I recently purchased a í96 Ford Bronco with the 351 engine. It has about 88,000 miles on it and runs really great. I want to change the oil on it but Iím undecided on what type to replace it with. According to the manual, the recommended weight is 5W-30 (at least thatís what I think I read) for the 351 engine. Iíve always used 10W-30 on my í91 F-150, but then again, itís only an inline 6. Do yaíll agree with this recommended oil weight? Whatís the most popular brand used? On my í91, Iíve always used Quaker State and recently switched to the High Mileage type Ė it has about 180,000 miles on it.
I also have a slight concern with something I think may be coming from the transmission. At take off, I feel a slight jerk, almost as if someone tapped my bumper from behind. I also feel this when Iím slowing down and about to stop. Is this normal or should I be concerned? It performed flawlessly during the 250 mile trip home when I purchased it.
Thanks in advance for any input.
Old 02-24-2004, 06:02 PM
jims89bronco's Avatar
jims89bronco jims89bronco is offline
jims89bronco is starting off with a positive reputation.
Down here in TX I've always used 20W50 due to the heat. It was recommended by a mechanic buddy of mine a while back. I've never had any problems, and it boosted my oil pressure a bit.
Old 02-24-2004, 07:08 PM
kameronth's Avatar
kameronth kameronth is offline
kameronth is gaining momentum as a positive member of FTE.
My 88 5.0 manual says to use 10-w30. It gets hotter then heck here too and I use 10-w40 in the summer. I used to use 20-w50 but if I let my truck set for a couple of days I hated to start it cold with that thick of an oil in it. Most engines in the 90's and up recomend 5w-30 because they are built a little tighter. If it were me I would just go by the manual.
Old 02-24-2004, 09:42 PM
If it were a lease vehicle, I would follow the recommended 5W30 because they foot the repair bills. Look at it this way...
5W30 is lighter/thinner- after warming up, it starts to thin out more. The hotter the oil gets, the faster it breaks down too. And when oil doesn't protect as it should, goes the motor! As we all know, engines don't like being HOT and lightly lubed!!
In this part of TX it gets HOTT in the summer, and not all that cold in the winter. 20W50 may be too thick for really cold winters, but going with the 3000mile oil change, you can always put 10W30 in for winter...
Like I mentioned before, it boosted my oil pressure too. I was using 5W30 and with my "loose" bearings I had 15-20psi at startup, dropping to 1-3psi hot. Now with the heavier stuff I have 30-35psi at startup and 10-15psi hot. So I know oil is circulating pretty well with the heavier weight oil.
Just my 2Ę...
Old 02-25-2004, 09:42 AM
I'm in south central Texas so I do understand HOT! Thanks all for your replies. I certainly appreciate the responses.
Old 02-25-2004, 10:21 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
I use Chevron Delo 15W-40 all year in Southern California. Temperatures here range from the upper teens here in the mountains right now to over 100 down in the desert in summer. 15W-40 is heavy duty "fleet" oil sold in gallons for diesel and gas trucks. It has more detergent/dispersant and ZDDP anti-wear additive than passenger car oil. Pennzoil LongLife, Shell Rotella T and Mobil Delvac are other popular fleet oils.
Jim
Jim
Old 02-25-2004, 10:51 AM
Crazyromi's Avatar
Crazyromi Crazyromi is offline
Crazyromi is starting off with a positive reputation.
This sounds like the take off/stop clunking that has been discussed many times in this forum. There can be several things that cause this, but the most common cause is the slip-joint on the rear drive shaft. All you need to do for that is slide the rubber boot to one side and grease the slip joint. Should take care of that problem. It did on mine. Use the search tool to find more discussions on this.
Old 02-25-2004, 11:26 AM
Quote:
15W-40 is heavy duty "fleet" oil sold in gallons ...
Sounds pricey. Is this stuff expensive?
Old 02-25-2004, 11:28 AM
Thanks, I'll do some searchin'.
Old 02-25-2004, 09:06 PM
kameronth's Avatar
It is not bad at all. I used to have a diesel and that is what I used. Maybe like 8 bucks?
Old 02-26-2004, 10:07 AM
Quote:
No, it is inexpensive since an oil change on a diesel takes several gallons, not quarts. $6-7 a gallon is what I pay. That works out to $1.50-$1.75 a quart.
Jim
89 f250 best oil to use?? Ape-louise 1987 - 1996 F150 & Larger F-Series Trucks 3 08-22-2014 02:59 PM
Quaker State oil change? Iowa F-150 2004 - 2008 F150 10 02-13-2011 09:55 AM
Do not use Quaker State oil Ed Oil & Lubrication 65 11-25-2007 01:04 AM
Best "dino" oil gtm245 Oil & Lubrication 24 02-01-2004 11:03 PM
Synthetic / Synthetic Blend Oil ????? sledhead999 1999 - 2003 7.3L Power Stroke Diesel 4 12-05-2002 06:47 PM
Tags
351, 351w, ford, motor, oil, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
