Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-23-2004, 10:38 PM
bikenbob is starting off with a positive reputation.
gauages
I have read alot in this forum about heat buildup with the PSD. Are aftermarket gagues a good idea on stock trucks? Or are they only required with aftermarket modications such as exhaust pipes or the Predator? I plan I some heavy towing in the desert this summer and do not want to fry anything!
__________________
'04 SD C/C Lariat 4x4 FX4 SB 6.0 PSD born 10/03/03
List Mod's in Gallery
FTE
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2004, 11:05 PM
ChiefGReid's Avatar
ChiefGReid is starting off with a positive reputation.
Even if you don't plan on chipping or programming your engine. If you plan on towing heavy items (like a 32 foot 5th wheel), then I would recommend at minimum a transmission gauge.
Might want to check
http://www.gosracing.com/home or
http://www.dieselpowerproducts.com/gauges
There are many other good people to deal with, but I have personal experience with these folks and they both will do right by you. They will paint your pod the same color (and I mean exact) to your interior.
A larger exhaust will dissipate engine heat faster. I also have a 04 and I do not intend to chip or program it until after the warranty is expired, (100,000 miles)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
