Cleveland cam bearings
Old 02-23-2004, 08:47 PM
Crazy Canuck's Avatar
Crazy Canuck
Crazy Canuck is offline
Was there ever a problem with cam bearing alignment from the factory in Clevelands.
Old 02-23-2004, 10:22 PM
grclark351's Avatar
grclark351
grclark351 is offline
not that i've ever heard, but i have heard of a recommendation thet the front bearing be set at .003? back from the front edge. not exactly sure why but it has to do with oil control.
Old 02-23-2004, 11:03 PM
Bill_Beyer's Avatar
Bill_Beyer
Bill_Beyer is offline
Yes there was. I've heard that it's because the factory bored half the bearing journals from the front and the other half from the rear of the motor but I don't have any hard evidence to back it up. I do know that some knowledgable sources will tell you if you don't have to replace the cam bearings during a rebuild then you shouldn't because you may end up having to blue & scrape the bearing inserts in order to make the cam fit properly.
Just as an FYI Cleveland and M block cam bearings also taper from front to back which means that each insert has a different diameter and they have to be installed in the correct order or you'll never get the cam installed.
pickenspolitics
18
08-10-2013 07:01 PM
f100odin
10-17-2010 08:16 PM
Draken
10-16-2009 05:06 PM
job1bf
11-09-2007 03:07 AM
335clevo
05-06-2002 08:13 AM
Quick Reply: Cleveland cam bearings
