Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-23-2004, 11:57 AM
bronc84 is starting off with a positive reputation.
swap 300 6 to 351M
Hi Everyone, just registered, looks like I've found a great sight for info! My question is I have a 84 F/S Bronco with a 300 I/L 6 cyl. and have found a donor 78 Bronco with a 351M in it. Both have standard trannies but I would like to keep the tranny that I have. How much work is involved swapping a six to an eight and will it bolt to my existing tranny? I asked a transmission guy and he said it would bolt right on without making any changes.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-23-2004, 10:49 PM
prostocktom is starting off with a positive reputation.
A 300 6 cylinder has the same bolt pattern as the small block 289,302,351W,and 351 C Your 351M uses a different pattern so you would have to change the bellhousing on your transmission to the bellhousing on the 351M. Other than that it should be fairly easy since you have the other truck to get everything you need.
  #3 (permalink)
Old 02-23-2004, 11:26 PM
Thanks for the info. Will the bellhousing from the 351m fit to my transmission?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
