02-23-2004, 09:58 AM
Your right the use of autopart store blocks can be controversial, like you said it has a warranty and they will exchange fairly easily, however, it will require your time to pull and install, potentially over and over.
IMO, find a local machinist that comes recommended, very important they be recommended by a few people, talk with them. It might cost about the same to have them do it, this way should you wanna bump the compression or adda performance cam, it won't be as big a deal and probably won't require as much out of pocket, than if you added these things after you received the longblock. Good luck with whatever you decide, btw, cleveland motors can make some decent hp with stock heads. An example in a performance book I purchased.
They took a 351c w/t 2v stock heads added:
**flat top pistons to achieve 9.25:1 compression ratio
**custom cam from John's Mustangs & Classics
110 lobe seperation
lift intake / exhaust .560 / .585
duration intake / exhaust 232 / 236
**edelbrock dual plane intake and holley 750 cfm
**msd ignition
**heddman hedders
hp on the dyno
2500.....................142
4000.....................273
5000.....................360
5500.....................391
6000 peak..............405
here is the good part
the torque
2500..................373
4000..................409
5000..................420 peak
5500..................410
6000..................387
Who knows, with a little more compression and newer designed camshaft (this book is kinda old) the numbers are bound to increase. something to think about, good luck
