Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-22-2004, 07:22 PM
chaindragger chaindragger is offline
Garage is empty, add now
chaindragger is starting off with a positive reputation.
Intermediate shaft on 2.3l 92 ranger
I've got a 92 ranger with a 2.3l motor. Problem is that the oil pump went or the intermediate shaft went. Question is if the shaft broke will the motor still start? Does the intermediate shaft control the distributor? Mine runs but makes an awful noise.
  #2 (permalink)
Old 02-22-2004, 08:08 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
It will run only long enough to seize up. You'll need to pull the oil pan to change the pump. You will have to lift the engine to get enough room to take the pan off. By the time you've disconnected exhaust & etc etc to get the hieght, you might as well pull the engine right out of the truck. At least then, it will be easier to change the pump & shaft.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
Tags
1986, 23, 23l, 90, auxiliary, change, engine, ford, intermediate, oil, pump, ranger, shaf, shaft, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
