How often you change your oil?
Old 02-22-2004, 07:17 PM
ItsReallyDarren's Avatar
ItsReallyDarren
ItsReallyDarren is offline
The Ford manual for my '03 says every 7,000 miles but I change mine every 5,000 with 5-30 synthetic.
Old 02-22-2004, 09:01 PM
whitescrew01's Avatar
whitescrew01
whitescrew01 is offline
I have an 2001 screw w/ a 5.4 and I change my oil every 3k w/ 5-20 motorcraft synthetic blend
BrilloDuck11's Avatar
BrilloDuck11
BrilloDuck11 is offline
I have a 2002 F-150 and my manual says every 5000 miles, i do it every 3000 just to be safe, plus one time i was a quart low after about 4000 miles, and I use 5w-20. hope that helps
Old 02-22-2004, 09:06 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
3000 miles with Motorcraft 5W-20 and always a Motorcraft filter!!!
Old 02-23-2004, 07:25 AM
50th ann's Avatar
50th ann
50th ann is offline
I change mine every 4,000 miles. my 1988 4.6L is still running like new at 119,000 miles. Same power, Gas milage as new and it does not burn a drop of oil. Valvoline 10W30. Multi grades are not as important in the south. Our tempeture dosent vary as much as the northern sataes
Old 02-23-2004, 08:27 AM
Bob Ayers's Avatar
Bob Ayers
Bob Ayers is offline
Every 3000-4000 miles, with Castrol 5W-30W, and nothing but a Motorcraft filter!!
Old 02-23-2004, 03:56 PM
FordTuff1's Avatar
FordTuff1
FordTuff1 is offline
I have a 1998 F-150 ext-cab body lift kit 36inch super swamper tires,i change my oil like every 2,500 miles or so rather be safe then sorry its your baby so take care of it!!!!
Old 02-23-2004, 04:30 PM
Liteamorn's Avatar
Liteamorn
Liteamorn is offline
My 03
The manual on my 03 calls for 5000, so I go 5000. Motorcraft synthetic 5/20 and motocraft filter
Old 02-23-2004, 08:18 PM
AzPete's Avatar
AzPete
AzPete is offline
I do our '01 F150 and our '95 Bronco at about 3000 miles. The truck has 36,000 miles and the Bronco has 123,000 miles. Now for the real used vehicle, the '02 E350 15 passenger van I drive for work with 275,000 miles right now (now problems or breakdowns). It gets the oil changed every two weeks, with 6580 miles every two weeks. (not a misprint on the miles) The van gets 470 miles per day, 7 days per week (no holidays), 5.4, Auto, Extended body. The '99 we had did 475,500 miles from Jan. '99 - Apr. '02 with only an alternator and a fuel pump taking it off the road for any time. Sold it for $8500.00. No other major problems.
Old 02-23-2004, 08:30 PM
grizz5675's Avatar
grizz5675
grizz5675 is offline
2001 f150 5.4 /every 3000mi.w/motorcraft 5/20
Old 02-26-2004, 07:32 AM
NHRstein's Avatar
NHRstein
NHRstein is offline
every 2000 to 3000
I use shell Rotella T 5-40 synthetic, this stuff works great for every vehicle I have ever put it in. they make a non synthetic if the "plastic" oils bother you, but it is 15-40 so I wouldn't use it in the newer fords where they usually call for 5-20 but it might make a good summer-time oil
//John
Old 02-26-2004, 11:25 AM
toxophilite's Avatar
toxophilite
toxophilite is offline
I have changed the oil three times (every 3K) on the 1997 F150 4.6 4x4 I bought last August. I always use Motorcraft 5w-30 with a Motorcraft 820S filter.
Lately I have been thinking real hard about switching to Motorcraft 5w-20 and extending my oil changes out to 4K.
Old 02-26-2004, 04:01 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
What? Am I suppose to change the oil in my truck? Just kiddin' I use Chevron Supreme or Havoline 10W30 with a Motorcraft 400S filter every 3k miles.
Starting this next oil change I will be making a blend for my engine. I will use 4 quarts dino and 2 quarts synthetic.
aj197816134
Modular V8 (4.6L, 5.4L)
03-18-2014 07:58 PM
PAf250
1999 to 2016 Super Duty
09-21-2013 08:08 AM
MadMaxZuki
6.2L V8
01-12-2012 09:20 AM
Sayer Lane
1997 - 2003 F150
06-13-2010 10:12 AM
expe00
1997-2006 Expedition & Navigator
09-05-2003 10:39 PM
Quick Reply: How often you change your oil?
