help hooking up camper brake light - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-22-2004, 02:17 PM
joedriver joedriver is offline
joedriver is starting off with a positive reputation.
I have a red wire and a black wire coming from the camper shell brake light. how do i hook this up?
its an 03 f250
Old 02-23-2004, 02:36 PM
Oklahoma Oklahoma is offline
Oklahoma is starting off with a positive reputation.
If I understand you right:
You need a test light, pocket knife, spare wire (same gauge on camper/PSD), electric tape. Maybe some electrical connectors and electrical pliers/crimper if you want to be fancy with it. With the tester, crawl under PU and locate either the wires leading to the PU brake lights or the trailer wiring before the female plug system. Have someone step on brakes and then you test for the 'hot' wire. Splice this wire into your shell red wire. Take the white one and ground to PU frame. The white ground wire is the weak link. Make sure to put in good location somewhere for corrosion protection. Tape up any splices and connections real good with tape.
This is only valid for normal BRAKE light functions. Running lights, turn signals, etc on a shell needs to be routed to corresponding wires on PU. If you also have these to do, buy yourself a 4/5 plug in type system just like a small pull camper or trailer. Everything from shell to trailers will use one spot this way. Will save you frustration in future when a light(s) doesn't work properly or the shell comes off.
Good luck and safe trips,
OK
Old 02-23-2004, 03:41 PM
JMorton JMorton is offline
JMorton is starting off with a positive reputation.
I originally wired mine that way and my third brake lamp on the shell would blink with the left turn signal.
I had to drop a wire from the cab's third brake light and run it down the frame and up into the shell to connect to the shell's brake light. Now it works as it should.
trailer battery charging wire? littlewhistlerlumber 1987 - 1996 F150 & Larger F-Series Trucks 5 11-19-2013 12:37 PM
Wiring in a trailer brake controller? 72Blazerod 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-07-2013 05:32 PM
Constant Hot Wire Spikebox 6.7L Power Stroke Diesel 5 12-14-2011 05:45 PM
Trailor Lights old rat 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-21-2011 08:53 PM
How do i test electric trailer brakes by myself? Franko72 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 15 04-14-2009 08:33 AM
Tags
03, 2005, aviator, brake, camper, connecting, connector, f250, hot, light, lights, plug, taillight, trailer, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
