Heater Resistor Problems ? - Ford Truck Enthusiasts Forums
Old 02-22-2004, 11:57 AM
Big Red's Avatar
Big Red Big Red is offline
Big Red is starting off with a positive reputation.
Unhappy More Heater motor problems... only one speed. What needs replacing?
My heater motor problems in my 1983 F100 continue... I thought I had all three speeds but it apears I only have high speed (fast and noisey!) which isn't too bad for the winter.
As you might recall, we had a 93cm (40in) snow fall; a real blizzard. The cowl and heating system was plugged with snowand when the truck was turned on the heater motor switch was set on the middle speed. Well I guess the motor couldn't turn because of the snow and I started to get smoke through the vents and a strong burning smell. I switched the blower off and the smoke and smell went away, Now I only have one speed... high.
My question is what do I replace to get all three speeds back? Just the motor or is it the switch in the dash?
Old 02-22-2004, 01:34 PM
kioolt kioolt is offline
kioolt is starting off with a positive reputation.
Most likely its the blower resistor. The resistor is what limits the current through the motor to make it run at the lower speeds. It is bypassed by the blower switch for high. Do a search on resistor and you will find a lot of information.
Old 02-22-2004, 02:10 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I just looked in the Haynes manual, and they show the resistor assembly mounted below and to the right of the blower motor. All you will see from the outside is a big plug with wires going into the heater plenum. The resistors are mounted on the inside of the duct so the airflow will keep them cool.
Old 02-22-2004, 02:14 PM
Big Red's Avatar
Thanks... found it OK. I am sure it needs replacement and it is too cold and snowy to check it. I will just order one tomorrow from either Ford or LMC Truck.
Old 02-22-2004, 02:42 PM
It is most likely the resistor but before you spend your hard earned dollars it might be a good idea to check it with an ohmmeter. You should have continuity between all the terminals. If you don't then buy a new one.
Tags
heater, heating, plenum, resistor, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
