Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-21-2004, 02:19 PM
oldtruck56721 oldtruck56721 is offline
Garage is empty, add now
oldtruck56721 is starting off with a positive reputation.
Ticking Noise
I have a 1949 F-1 with the V-8 Flathead in it. I recently got it to run very good except there is one probem, there is a ticking noise in one of the valves or the lifters. I dotn want to pull the whole motor apart, but does anyone have any "old tricks" to get this problem out of the motor? Also when it runs it smokes very blue, and smokes a lot. Oh yeah and could any one tell my why when I try to hook up the alternator it burns the wires right off? The whole motor has been converted to 12 volt if that helps. Thanks in advance.
  #2 (permalink)
Old 04-07-2004, 11:46 PM
lymant lymant is offline
lymant is starting off with a positive reputation.
Sorry But You May Have To Pull The Manifolds To Get To The Tappets To Adjust Them,one Or More May Need To Be Adjusted.blue Smoke If Engine Has Not Been Run In Years It May Need To Run Awhile To Reseat The Rings Or It May Be Time To Rebuild If Engine Warms Up And Oil Pressure Drops Low I Would Recommend Rebuild.
Late Reply I Didn't Know That This Forum Included Flatheads. :-x17
  #3 (permalink)
Old 04-08-2004, 07:10 AM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
Standard Flatheads didn't come with adjustable tappets you had to set the gap by grinding the valve stem although adjustable lifters were and still are available as a aftermarket upgrade
I would remove the inlet manifold turn the engine over by hand (with the plugs out), you may be able to see if you have a stuck valve or a broken spring.
Could it be the fuel pump or push rod ?
I agree with Lymant on the smoking, a compression test may tell you a bit more
No idea what could cause the wire to burn
Good Luck
Stephen
  #4 (permalink)
Old 04-09-2004, 09:36 PM
56f600 56f600 is offline
56f600 is starting off with a positive reputation.
On the wire burning from alternator. Positive or Negative ground? If truck is Pos. and alt. is Neg. that could do it.
__________________
Mark
1956 F600
flatbed dump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
