Heater Control - Ford Truck Enthusiasts Forums
Heater Control
Old 02-21-2004, 02:06 PM
jayrak jayrak is offline
jayrak is starting off with a positive reputation.
Unhappy Heater Control
My 1993 F 350 is without heat, AC works fine, just picked the truck up in Florida, back in Michigan it is cold. The heater hoses are hot up to the fire wall so I think water is flowing through the heater core. Is there a heater control module that might not be working? Where is it located and what does it look like.
Thanks, Froze in my Cab
Old 02-21-2004, 04:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Not sure on the 93 but on the 86 there is no water control. Heat is regulated by a vacuum operated door that controls where the air comes from on one side, and where it goes to on the other side.
The door controller is behind the glove box on mine, it may have had something drop in the defroster vents and block it in the cool position.
Old 11-04-2005, 10:38 AM
stangclassic66 stangclassic66 is offline
stangclassic66 is starting off with a positive reputation.
Hey Dave, I've got an '86 and my cab seems to stay warm all the time. A little too warm. Nothing I do on the control panel helps.
Can you describe what to look for behind the glove box?
Thanks in advance.
Erik
Old 11-04-2005, 10:40 AM
Dave, one other thing. I can't seem to get air to come out of the air vents. Only on the windshield and I believe the feet area. I know for sure the windshield defroster... not 100% sure on the feet area.
Old 11-04-2005, 09:19 PM
wh336fire wh336fire is offline
wh336fire is starting off with a positive reputation.
Howdy Erik . Check your vaccum going into the cab . Could be a bad ac/heater control switch also. If you remove your heater core , you will see the door dave is speeking of . I know this because mine is broke . I have to replace the door to make my vents operate properly .I don't remember if the door is vaccum or cable operated .I'll look at mine in the morning .
Jayrak . Your heater core could be clogged . I had to flush mine today . Took me a little while , but I finally moved some water through it . Both my heater hoses were hot even though there was no water moving . Anyhow , something for you to look at .
Good luck .
Old 11-05-2005, 12:05 AM
Sounds like you vacuum is low.
The selector valve is vacuum operated, if you loose vacuum it defaults to the defrost position.
Also you should notice lots of foot pressure required to stop the truck if it is the pump.
Old 11-05-2005, 12:48 PM
Dieseldan7.3's Avatar
Dieseldan7.3 Dieseldan7.3 is offline
Dieseldan7.3 is starting off with a positive reputation.
my 89 would not change vent positions because of a vacuum leak in the line going to the selector valve thingy below the dash. I dont think that controls the heat or cold, just where it blows out.
HOld on now, if 93 is the new body style then the heater controls are just ***** that are electronic I thought. They are completely different then our 83s-91s.
Heater hoses cold, ne heat RLKBOB Cooling, Heating, Ventilation & A/C 1 12-26-2011 06:13 PM
'98 Ranger heater control valve ekoncepts Ranger & B-Series 7 10-28-2009 12:07 AM
Heater hoses Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-23-2009 02:17 PM
heater hunter1988 Ranger & B-Series 2 12-11-2008 07:30 AM
Plug for block heater Demolition 6.4L Power Stroke Diesel 18 11-01-2008 09:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
