Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-21-2004, 10:44 AM
79redranger's Avatar
79redranger is starting off with a positive reputation.
Question 351M and a 351W
My 79 f150 has the original 351m in it and i'm planning on swapping it for a rebuilt W. A friend of mine said there might be problems bolting up to the c6 tranny. Would there be a problem? please explain. What should i do?
__________________
1979 F150 Ranger XLT 2wd 351M C6
1996 Ranger XLT 4.0 5spd
2002 Ranger XLT 4.0 SOHC Auto
High Plains Drifter
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-21-2004, 11:26 AM
82F100SWB's Avatar
82F100SWB is gaining momentum as a positive member of FTE.
To put that 351W in there, you're going to need mounts and stands for a 302 truck, and a smallblock C6, the M uses the big block bolt pattern.
__________________
86 F250 HD, 4x4/460/T19/44HD/10.25
82 F100/86 F350 4x4 460 with some goodies/T19 D60/welded 10.25/38.5 Boggers, mud racer/wheeling pig...
81 F100/86 F250 HD 4x4, 6.9/T19/D44 TTB junk/10.25. All smoke, no power, turbo no more...
And a couple Brand D's with early "C" power
It's not what you BUY, It's what you BUILD
  #3 (permalink)
Old 02-23-2004, 12:19 PM
loudfords's Avatar
loudfords is starting off with a positive reputation.
The stands are the same for 351M/351W/302. The motor mounts are the same for 302/351W different for 351M. The transmission bellhousing bolt pattern is the same for 302/351W different for 351M. Just get a C6 from an 80's truck/van with 302 or 351W.
__________________
Chad - loudfords
1979 F150 351W
2001 Focus
Ford LT75 lawn tractor
  #4 (permalink)
Old 02-23-2004, 11:53 PM
prostocktom is starting off with a positive reputation.
Just take your tranny to a tranmission shop and have them change it to a small block C6 case. Get your motor mounts at AutoZone or PEP Boys there cheap there.
  #5 (permalink)
Old 02-24-2004, 10:23 AM
Mike G is starting off with a positive reputation.
Chances are you shop will not "change" the case, they will sell you a different tranny that will be required to go to the small block bolt pattern.
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
