Track Bar Bolts Too Small? Poping Noise - Ford Truck Enthusiasts Forums
Old 02-20-2004, 05:02 PM
chspyder's Avatar
chspyder chspyder is offline
chspyder is starting off with a positive reputation.
Question Track Bar Bolts Too Small? Poping Noise
Ok after searching long and hard thru threads and sites for any help on the 99 F250 super duty I have found my noise problem, the bolts in the track bar (not the sway bar!) are too small, I have had this noise off and on since I bought the truck I thought I could eliminate if by replaceing all components in the front, so I bought a lift kit and replaced everyting, but the track bar, and found that the bolts are too small for the track bar holes I need some one to let me know if this is normal, or should I replace the track bar, or get larger bolts and drill out the supports.
And please dont reccomend me an adjustable trackbar, I have seen those and they are not worth the money!
Thanks!
Jt
torque specs on track bar bracket? P4IN COMM4NDO 1999 - 2003 7.3L Power Stroke Diesel 18 10-12-2016 06:09 PM
Track bar ball joint flip jlmotox 1999 to 2016 Super Duty 5 08-07-2016 02:22 PM
track bar bracket ecampbell124 1999 - 2003 7.3L Power Stroke Diesel 4 03-06-2016 10:04 PM
Track bar bushings or do I need the whole bar BMWM1 1999 to 2016 Super Duty 2 07-27-2009 11:31 AM
Track bar bolt torque dmgiff 1999 to 2016 Super Duty 2 01-28-2005 07:27 PM
Tags
99, bar, bd, bolt, dvd, f150, ford, noise, sale, small, superduty, track, trackbar, truck, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
