Tailgate won't open!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-02-2002, 08:16 AM
Flrsdgy Flrsdgy is offline
Flrsdgy is starting off with a positive reputation.
I just got my truck, and have spent all my time at the front end and underneath. I discovered that the tailgate won't open, and suspect that the mechanism needs to be lubed. How do I go about getting it opened so I can commence to lubin'? Thanks for any help you can give.
"Quadzilla"
'95 F350 Crew Cab 4X4 PSD.
35" tires on 10" rims.
(Thank God for a wife
that likes big trucks.)
Old 02-02-2002, 09:00 AM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
You may have to undo the tailgate handle so that you can get to the rod actuators themselves. Maybe a pull with some vise-grips on each one. Or mainly so you can see what's goin' on in there. Somtimes a rod can fall off or get bent out of shape. Also helps if you push on your tailgate while lifting the handle. Relieves tension.
Now, I had to do this with many ch*vy's. I may not work on your but I can't imagine the design being too far off.
Once open, I would recommend "penetrating grease" not WD-40. (Use that first) The grease sprays like WD-40 but sets up nice and gooey. I love the stuff. You should be able to find it at a good auto parts store. I use the ZEP brand...
Old 02-02-2002, 09:08 AM
Thanks, Monsta. Once the sun comes up, I'll try that.
"Quadzilla"
Old 02-02-2002, 10:27 AM
DaleL DaleL is offline
DaleL is starting off with a positive reputation.
but, is it locked? :-)
DaleL
Old 02-02-2002, 10:30 AM
Monsta's Avatar
I don't think the '95's had locking tailgates...but that was MY first thought!
Old 02-02-2002, 11:43 AM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
I seem to remember my '93 F150 having a plastic clip that didn't always hold onto the latch rod the way it was supposed to. Mine never broke, but I've heard of some that did.
Old 02-03-2002, 06:24 AM
I got it open, and got her all lubed up. Mine doesn't have a lock on it, it was just that the latch mechanism on the right side was stuck. After a fair amount of shakin' and bangin' it finally came open. Thanks for your help.
"Quadzilla"
Old 02-03-2002, 10:38 AM
oleblue70 oleblue70 is offline
oleblue70 is starting off with a positive reputation.
Rear Window Won't Open trshman Expedition & Navigator 5 11-07-2012 07:56 PM
Tailgate stuck jslaymon 1987 - 1996 F150 & Larger F-Series Trucks 7 04-13-2011 08:55 PM
Tailgate Won't Open makthenif Expedition & Navigator 6 11-29-2010 07:12 PM
96 ranger tailgate stuck bro chuck Ranger & B-Series 8 06-01-2007 08:04 PM
'90 Tailgate won't open. NitrousAl Ranger & B-Series 8 01-16-2005 08:14 AM
Tags
2001, f250, ford, open, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
