Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-19-2004, 08:27 PM
CAT_man_963's Avatar
CAT_man_963 CAT_man_963 is offline
Garage is empty, add now
CAT_man_963 is starting off with a positive reputation.
What tank for propane injection??
I need to know what kind/type of propane tank I need for a propane kit for my truck. I'm assuming that a regular barbecue grill tank ISN'T what I want. Can I use a horizontal/vertical tank - like what is used on forklifts?? Or do I have do get some special tank from the company that makes the Propane Injection kit??
I'm looking to mount it somewhere under the truck and I picture one of those forklift tanks tucking nicely between the body and the frame? ANY input would really help!! Thanks guys!
__________________
-Chad
'02 F-250 PSD 4x4 with a few mods, here and there
  #2 (permalink)
Old 02-20-2004, 12:14 AM
Jlower's Avatar
Jlower Jlower is offline
Jlower is starting off with a positive reputation.
Quad can give you a really good run down on what you need. I think you'll also have to re program that chip you ordered so it will work with propane.
__________________
03 F-350 CC LB Lariat 7.3 PSD 4X4 DRW/ Plenty O' goodies---Dare to race ?
SIGINT/ELINT - In God we trust, all others we monitor.
  #3 (permalink)
Old 02-20-2004, 04:58 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
It depends on which propane system you install. If you go with a vapor system like the Powershot2000, you'd want a vapor tank. A BBQ tank is a vapor tank, but doesn't supply enough vapor to feed the system, but you could use two in tandem. I've got a 9.9 gallon Manchester tank mounted under the bed of my truck, and can go 2000-3000 miles between fill ups. Click here for pics of my setup.
If you go with a liquid system, like the Bully Dog, you'd need a different tank, but I don't have a lot of experience with that system.
If there's more I can help you with, let me know.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #4 (permalink)
Old 02-20-2004, 07:05 AM
Thanks for the info - it's a vapor system that I'm asking about - the Powershot2000. Does anyone know what the forklift tanks are? Vapor tanks or no? The reason I'm asking is 'cause I have easy access to some used ones in good condition for a decent price.
__________________
-Chad
  #5 (permalink)
Old 02-20-2004, 07:23 AM
fast freddie fast freddie is offline
fast freddie is starting off with a positive reputation.
Cat man, You might want to check the local wrecking yards for a tank off of a motor home. They are horizonal. vapor tanks and have a level gauge installed on them. Would probably have suffcient flow capability since it is designed to provide flow to the stove, oven and heating system at the same time. Just a thought...
  #6 (permalink)
Old 02-20-2004, 08:17 AM
Well I got one answer - forklift tanks are liquid-draw tanks, NOT vapor tanks - so there goes that idea down the crapper. Now I'm wondering about using the 2 BBQ tanks hooked together - I know I'll have to get a custom part made up but I've already got about 10 regular sized BBQ tanks sitting around so I wouldn't have to spend the money for a tank.
__________________
-Chad
  #7 (permalink)
Old 02-20-2004, 06:05 PM
Quadzilla's Avatar
If they're OPD tanks, you'd be fine with two of them. My buddy also has a PS2000 and runs that setup. He's got a hose that splits, and connects to both tanks simultaneously. His works great, and he can take the tanks out of the bed of his truck and fill them. My tanks is permanently mounted under the truck, and I just have it filled like a motorhome.
__________________
  #8 (permalink)
Old 02-20-2004, 09:21 PM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
maksure your tanks have the DOT approval too, i got a nailed for not having it on my work van, i got a tank off a wrecked motor home, and im running the bullydog system, soon to have it on the pickup truck. thoose hose splits they will have at any rv store also if its over #30 tank the OPD is exempt
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
Tags
3000, 95, aerostar, diego, diesel, injection, propane, san, tank, tanks, truck, vapor, vertical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
