how important is MAF sensor?
I just used a sensor checker from my auto class and found my mass airflow sensor is only putting out around .20-.30volts and its supposed to put out between .70 and 1volt. How important is this sensor to performance. I could get another for around $100 but and a little strapped for cash right now. What would this sensor do to performance and gas mileage. BTW its a 94 ranger 2.3l.
The MAF has an electrically heated wire that is cooled by the air coming in. The more air, the cooler it gets. Many times you can take it out, and clean the wire (small small small) with a q-tip and some rubbing alcohol. It is very delicate, so be careful if you try this... the more it costs to replace, the likelier it is that you break it...
If you disconnect the MAF, the ECM will use 'default' or 'creep home' settings. If it is getting good mileage, and running smooth, I'd check my measurements again. Test it using the procedure that FoMoCo recommends...
tom
tom
JSTJ704
07-23-2014 07:44 PM
brianmorgan17
04-14-2014 08:25 PM
DasCheckers
12-15-2010 10:48 PM
