Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-19-2004, 11:35 AM
FLFordOwner is starting off with a positive reputation.
No climate control on max ac full cold no blending
have a 04 f250 Lariat CC 6.0
on Max a/c the only setting that does not allow outside air in i only get cold no heat or blending at all is this right ?
This is manual control and truck is hot
my 150 xlt super crew allowed me to blend and heat while on max a/c
thanks for the info
__________________
2004 F250 SD SB FX4 6.0 Psd Crew Cab SRW Lariat green replaced @45k miles
2006 F250 SD 6.0 PSD SB Crew Cab Srw Lariat FX4
1978 F100 Reg Cab 4x4 302 w/4 speed lifted on 35's
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-20-2004, 10:37 PM
wow nobody see's this as a problem ? ford isnt quality job 1 anymore
sad to say im thinking of trading this month old truck off for a chebby
waiting on the service manager to tell me if they are installing a new a/c system in this truck or correcting this problem
__________________
  #3 (permalink)
Old 02-20-2004, 11:38 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
To the contrary, it could mean that others don't have this problem or that that truck is new enough that most have no experiance with it.
To say that you will trade it for a chevy after one minor problem (which the dealer is trying to fix) sounds suspect to me.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #4 (permalink)
Old 02-20-2004, 11:58 PM
Minor problem?
i sit in my truck all day and the fumes make me ill as i drive through traffic . what happens when i take the truck for a trip stop at a truck stop to rest and if im running the heat i have no choice but to draw fumes into my vehical and maybe kill me and my family while we rest
I cant even goto the bank and run the heat while im in line at the teller my truck fills with fumes from the car in front of me i have to turn off my heat or ac if i dont want it on full blast cold
there is 500 places that i have to turn off my ac now that i could run it before with my 2001 f150 if i wasnt in my truck at least 5 hrs a day it still wouldnt be minor
If they dont fix it, sorry but It WILL be the last Ford i own no other story other than the ac the truck runs great looks great in the driveway but lost desire to drive a vehical i get sick in
__________________
  #5 (permalink)
Old 02-21-2004, 12:01 AM
Please let us know if your dealer fixes the problem.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #6 (permalink)
Old 02-21-2004, 12:04 AM
will do, i hope he does .. still like to know if others are having this problem and if they have had the dealers fix it or what happened ...
Thanks
__________________
  #7 (permalink)
Old 02-21-2004, 12:23 AM
I could move this one to the SuperDuty forum so that you can get more help if you wish. Your truck is very new and that forum may be more helpful.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #8 (permalink)
Old 02-21-2004, 02:09 AM
i have one in the 6.0 forum but maybe the superduty forums is better ?
any help you could give is appreciated
Thanks
__________________
  #9 (permalink)
Old 02-22-2004, 10:00 PM
jessfactor is starting off with a positive reputation.
i have a 95 f150. if i move the dial all the way to the warm side while running max ac does my compressor still run?
__________________
95 F150 XL 4.9 M5OD(zoom zoom)
its all about the low end truck power
  #10 (permalink)
Old 04-03-2004, 11:21 PM
Quote:
yes it will recurculate but mine still blows ice cold when on heat
__________________
  #11 (permalink)
Old 04-03-2004, 11:22 PM
Update ford wants me to DSB the truck they said its a defect and they have no fix
still looking at my options
__________________
  #12 (permalink)
Old 04-04-2004, 01:01 PM
HomerWinzlow's Avatar
HomerWinzlow is gaining momentum as a positive member of FTE.
Straight from the service manual...
System Airflow Description — Manual Climate Control
Max A/C
When MAX A/C is selected:
The air inlet door vacuum control motor is at full vacuum, closing off outside air and admitting only recirculated air.
The panel/defrost door vacuum control motor is at full vacuum and the panel/floor door vacuum control motor is at no vacuum position, directing airflow to the instrument panel A/C registers.
The heater control valve (if equipped) is at full vacuum, preventing the flow of hot coolant to the heater core. Blended air temperature is not available.
The A/C compressor will operate if the outside temperature is above approximately 6°C (43°F).
The blower motor is on.
The auxiliary blower motor (if equipped) is enabled. Blended air temperature is not available
Have you gone out to the truck and looked to see if it has a water control valve? You could simply unplug the vacuum line and plug the open end of it. That would allow water to flow and heat operation I believe for your special circumstance. Its hardly a defect since manufacturers have used them for eoons in Max cooling conditions on vehicles that need the extra cooling performance.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #13 (permalink)
Old 04-04-2004, 01:48 PM
That would fix my problem yes, but ford told me if i do that they will void my warrenty , i have owned many ford products and i have never had this pos a/c system
they tell me to run my a/c on normal when i do that my cab fills with fumes and makes me ill .. when i run the heat the truck fills with fumes and makes me ill also
so it comes down to full cold a/c or smell fumes, im a 50k truck i think this is a joke to have no climate control while recurculating inside air
Thanks for the input
sorry it may seem petty but i work out of this truck and sit in it all day to have no climate control in my office is unthinkable
on max a/c on low setting the truck freezes you out of it i dont see the need for extra a/c power but i may install a ball vaulve to fix it and screw my warrenty
__________________
  #14 (permalink)
Old 04-04-2004, 01:52 PM
I dont know why they would tell you that unless it would damage the system doing so. Someone is yanking your chain maybe.... could it be because you are yanking thiers with threats to trade it off for a chevy? Plug the damned vacuum line and when you take it in for warranty repairs restore it back to normal. Dont get yourself all twisted in a knot over a simple remedy.
No manufacturers system works in recirculation mode (MAX AC) in a heated mode without a separate recirc switch.
__________________
My Missing Michelle
  #15 (permalink)
Old 04-04-2004, 04:44 PM
This is my 2nd truck with them in 3 yrs if they want to get number 3 they should work with me
my 2001 f150 super crew 4x4 i could heat the truck on MAX a/c or set it to any temp i wanted with out any extra button, this truck has same settings and controls as my 2001 F150
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
