Go Back   Ford Truck Enthusiasts Forums > Other Fords > Nite, Nascar and Other Limited Edition Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-19-2004, 11:35 AM
Niteman821 is starting off with a positive reputation.
Question My 92 nite has issues's can anyone help
well first off.....its a 1992 ford f150 nite with a 5.0 in it....now for the issues......the starter went out in it and i rebuilt it and now all the thing does it click when your try and turn it over and if you touch the siliniod with a screw driver it still wont start....then before the starter went out it had a mist....but it wouldnt mist if u had the gas pedal to the floor.....otherwise it would mist pretty bad the slower you went....i replaced the distrubutor cap, rotor, spark plug wires and o2 sensor......well thats about it so if anyone knows what could be be causing these problems i would greatly appraciate the responds.
thanks Zach
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-16-2004, 03:37 PM
lillightnin is starting off with a positive reputation.
Did the truck smoke like its carboned up?Were the plugs black when you changed them?My 92 Nite did this and it was the fuel pressure regulator needed replaced.As for the starter it sounds like it was put together wrong or you got some bad parts.
  #3 (permalink)
Old 03-22-2004, 11:18 AM
thanks for the advice ill try replaceing the that i havent noticed any smoke though but the plugs were a little on the burnt side when i replaced them
  #4 (permalink)
Old 03-23-2004, 05:28 PM
Lightning Fast Fords is starting off with a positive reputation.
Niteman,
From having had bad experiences with starters in the past , my suggestion would to buy a unit from a Ford Dealership. I would also be hot to trot on inspecting all the wiring going to the starter , battery and solenoids too. I tend to agree with the previous poster on the current starter however , either something was missed ?...or second rate materials came in the kit.
Sure , you are going to pay a few bucks extra Vs. an Autozone or a Pep Boys , but a "Remanufactured Unit" from Ford is about as good as it gets. The best scenario is to make friends with your local Ford Dealers parts people....and see if they will hook you up with a semi-bogus account that will allow you to purchase all your Motorcraft needs at "Jobbers Rates"
Should the above work out for you? You will be enjoying some need savings and insuring Factory Spec parts going back on your Nite.
BTW...I sold Fords from late 92 -94.....and the 1992 Nite was always one of my favorite vehicles during that time. I sold a couple of the F-150's in the Nite configuration...but never a Bronco , we never had one to sell
FYI....I would not pass on a chance to own a nice example of a 1992 Nite....so keep me in mind.
  #5 (permalink)
Old 03-31-2004, 09:50 AM
Lightning Fast Fords,
Hey thanks for the advice i'll swing by the dealership as soon as i get some free time and do that and i will write back saying weather it worked or not....sorry it took so long for me to reply my comp kinda died and i just got around to buyin the new parts to fix it....as far as the nites i have loved them trucks or at least mine since my dad first bought it.....and had my eye on it until i turned 16 and then he let me buy it from him.....great truck and it still ran strung up until the miss and the starter went on it and it has about 147k....next summer im goin to work on restoring it.....body has some minor dings and needs a paint job because a f-in bob cat backed into the box of it when i had new tires put on it
thanks for the help
niteman
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
