Is the 4.0 SOHC a zero clearance engine - Ford Truck Enthusiasts Forums
Old 02-18-2004, 08:28 PM
Powerkleen Powerkleen is offline
Powerkleen is starting off with a positive reputation.
I am having problems with my explorer with the 4.0 SOHC engine. I think the timing chain or the tensioner is broke. The fuel mileage has dropped some over the past few months. Then the other day when my wife was driving the engine died and lost all power steering and power brakes, of course. She had to fight to control the vehicle, thankfully her and the baby were okay. Had vehicle towed and getting ready to work on but someone said something about this engine may be a zero clearance engine that would bend the valves and damage other parts inside.
Is this a zero clearance engine or what?
Thanks for any help from you guys and gals.
Anthony
PS. I am currently going round with Ford over whether or not they will cover this under the 01m01 program that they have issued.
Old 02-19-2004, 04:20 AM
dubtub dubtub is offline
dubtub is starting off with a positive reputation.
01m01 program , would you tell just a little bit about this campaign program, I am very curious. More said the better, in my book!
Old 02-19-2004, 04:53 AM
This is like a silent recall that Ford said they mail notice out 1 time and thats it, unlike a safety recall that they keep sending you notices. The 01m01 program was dealing with Ford saying that there is a problem with the cam chain guide assembly. There are other programs dealing with the cam chain tensioner wearing and breaking. Ford said these are not safety recalls. When my wife was driving the other day and it messed up and she was trying not to wreck with her and the eight month old baby in the back, I consider this SAFETY, no matter what Ford calls it. Check the recalls/tsb on this site and also go to Ford's website and put in your vin number and check for recalls.
02 explorer 4.0 sohc engine help!!! f2504x4man Explorer, Sport Trac, Mountaineer & Aviator 4 10-27-2011 11:46 AM
01 SOHC 4.0 cold poor idle, no code, good IAC RCWMTW 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 12 12-22-2005 10:14 AM
Remove Transmission Filter on 1998 Explorer ptd0647 Clutch, Transmission, Differential, Axle & Transfer Case 1 09-08-2003 08:39 PM
How can i tell if i have a sohc or ohv? wrcummings 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 5 08-30-2003 06:25 PM
Pushrod vs SOHC - Pros and Cons? thelonerangerxlt Explorer, Sport Trac, Mountaineer & Aviator 11 08-03-2002 05:47 PM
Tags
01m01, 40, 99, campain, chain, clearance, clearence, clernce, engine, engines, explorer, ford, moter, sohc, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
