Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-18-2004, 06:48 PM
brent91 is starting off with a positive reputation.
Clutch pushed in...Nothing Happen
Today i was pulling into a parking spot and i pushed in the clutch and the brake to stop. The clutch went to the floor and the truck stalled. There is no back pressure in the clutch. If I lift it up with my foot the spring pops it to the up position. When I try to press down on it, the spring slams it to the floor. No start with No clutch. Needless to say I had to call for a ride home. 2nd time stranded in my 10 years of driving 2 F150s.
'96 F150 5 spd manual 130,000 miles 4.6L(4.9L, whatever it is).
How bad does this sound?
  #2 (permalink)
Old 02-18-2004, 06:53 PM
steell is starting off with a positive reputation.
Sounds like a master or slave cylinder is needed.
And, why can't you drive it with no clutch pedal? Just start it in gear.
Hmm, newer vehicle, have a neutral safety switch to stop you from doing that?
  #3 (permalink)
Old 02-18-2004, 06:56 PM
The clutch pedal is physically there. It just isn't doing anything except poping in and out with no results. I tried to start it back up, but it does the same thing as not having the clutch pushed in.
  #4 (permalink)
Old 02-18-2004, 07:03 PM
Does it crank over? If so, do you know how to shift without using a clutch?
My ex-wife broke the clutch quadrant in her Mustang again(same symptons as yours). The starter interlock switch on her Mustang is on the clutch pedal, so I was able to start it in gear and drive it back to her house.
Divorced for seven years and I still have to work on her car
  #5 (permalink)
Old 02-18-2004, 07:57 PM
Doesn't crank over.
Just got off the phone witha friend and he was thinking along the line of a slave cylinder. He said he had a similer thing happen to him and he got a $20 rebuild kit and it ended up being a "o" ring inside it. Atleast that's what i think he said was wrong.
  #6 (permalink)
Old 02-19-2004, 04:27 PM
jim henderson has a good reputation on FTE. jim henderson has a good reputation on FTE. jim henderson has a good reputation on FTE.
I had this happen once with a Datsun way back. I was able to drive 200 miles home this way and even stop for gas etc.
I would agree it is likely the clutch cylinder, either master or slave, or if mechanical, it's the linkage or cable.
I could still start the engine, I think your will too as long as the clutch is depressed enough to turn off the interlock switch.
Once it is running you can kind of "nudge" the shifter into gear. then as you speed up you can find the speed where the tranny synchros are fairly matched in speed to what you are doing, and "nudge" it into the next gear.
There is kind of a knack to "nudging" it, but if you do it right, the gears won't grind, even going into 1st.
At least that is my experience 20 years ago with a rice burner.
Good Luck,
Jim Henderson
  #7 (permalink)
Old 02-19-2004, 04:38 PM
77'F-150Mudder is starting off with a positive reputation.
Sounds like either the clutch slave or master.
Do you have any fluid leaking underneath the truck. In other words, check the slave cylinder for leakage. Usually when those go they start puking everywhere.
Also check for brake fluid leaking into the cab. That would be a sign of a bad clutch master.
EDIT: Don't cheeze out and buy a rebuild kit. Pony up and buy a new one. You'll be bucks up in the long run.
__________________
Scott
  #8 (permalink)
Old 02-28-2004, 11:47 AM
After a little hasle in the dark I found out that the push rod came off the linkage. Quick fix, put it back on. That worked until yesterday when the plastic piece on the end of the push rod snaped in half. Why would they make the whole push rod metal the put a plastic piece of crap on the end that brakes. I believe that i have to replace the whole clutch mast cylinder now, I have it almost off but the manual says to disconnect it from the hydrolic line. Sounds simple, but how do I do that? I have the 2 nuts off and the switch assembly off. Everything is on the enigine side now. Just sitting there. Help? I see no nut keeping it on and it will turn 360 while on the hydrolic line.
  #9 (permalink)
Old 02-28-2004, 11:20 PM
There is a pin that locks the line into the cylinder (and an o-ring between the hose and cylinder). Just push the pin out and the hose will come off.
And don't forget to replace the o-ring when you put it back together.
  #10 (permalink)
Old 02-29-2004, 04:57 PM
bob arrington is new and has a neutral reputation at this point.
kept my boat and moved 2500 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
