Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-18-2004, 01:43 PM
frenchf250 is starting off with a positive reputation.
Angry hELP leaky injector pump
On cold mornings I am having some fuel leaking from somewhere in front of the pump. It leaks for about 5 min. and then it stops. It only leaks when engine is cold (fast idle) then stops. I know it's leaking from the front somewhere but don't know where.
What could it be?
__________________
1990 F-250, 4x4, 302 cu.in, 230 000 kms
  #2 (permalink)
Old 02-18-2004, 02:39 PM
RayHell is starting off with a positive reputation.
Hi, got the same problem, so I'm waiting for replies on this too..
  #3 (permalink)
Old 02-18-2004, 08:49 PM
75diesel is starting off with a positive reputation.
most generally it could be from a throttle shaft seal, top cover, or side cover, when in "cold mode" the cold advance solenoid closes the return(hose out the top) to gain timing advance, this in turn increases the amount of internal pressure inside the pump. Carb cleaner, flashlight, and a mirror to hopefully find the source, hope I have been of some help.
__________________
'75 F-250 4x4,6.9Lw/turbo,5-Spd,4.10
List extras & Mod's in Gallery
FTE
  #4 (permalink)
Old 02-18-2004, 10:55 PM
grtF250 is starting off with a positive reputation.
About a year ago mine started doing the same thing. About a month later it stopped leaking when cold. But started leaking when hot. (5 to 8mpg) it wasn't that hard to figure out. In the end I had to replace the injector pump. I hope your problem has a cheaper solution.
If you do end up replacing the injector pump do it your self or hire a good mechanic. I was new to the area and hired a highly recomended shop that claimed they worked on diesels all the time. 3 pumps and 9 return trips later I bought a book and timed it myself. (that was an expensive lesson)
Again, I hope there is a cheaper solution to your problems
__________________
91 f250 7.3I 5spd 4x4 160k ext cab. No soup bowl
  #5 (permalink)
Old 02-19-2004, 06:15 PM
bilder12 is starting off with a positive reputation.
Try feeling this area for the leak at the pump if nothing else is visible:... where the pump mounts to the engine is a flange with 3 nuts holding it on (they are 9/16 wrench) right behind this area is neck of the pump and at the very bottom of this neck is a weep hole. It is a real bear to get your finger under this area, but I had 3 rebuilt pumps leak here. They would leak, they wouldnt leak. Made me a drinker (besides my wife). You can wipe the area by passing a dry rag thru and run it back and forth. This is my 2 cents worth and hope it helps.
__________________
2000 super duty f-350 crew cab with training wheels, ats flip chip controller - hang on to it ! I did the air intake too - best thing since sliced bread.
  #6 (permalink)
Old 02-20-2004, 10:09 PM
loudwayne is starting off with a positive reputation.
Hey,builder12
Will a fresh rebuild on a injector pump(& injectors) make the E4OD
operate with greater efficency??
LoudWayne
& the Blue Beast are back!!
__________________
W.B.Robinson
'92 F250 XLT, 4X4, 7.3 i.d.i E4OD,
No Soupbowl, stock ex.
A reman I.P.fresh injectors!!
Mpg's= a full 20mpg(Cdn.), for real!!
  #7 (permalink)
Old 02-21-2004, 10:04 AM
Wayne, I dont know what a rebuild has to do with the trans operating but I would imagine a "full tune up" would make the engine more efficient. The switch on the pump for the trans would have to be readjusted too. I dont know what the hell they call it FLIP ... FILP I dunno but it makes the trans down shift and all that stuff. I dont do transmissions (especially slush boxes) to be honest with you.
__________________
  #8 (permalink)
Old 02-21-2004, 01:30 PM
you got about as much as I do on these subjects,thanx for the answer
back to frenchf250
__________________
W.B.Robinson
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
