ive got cats and straight pipe thats it.............its loud......ask jimmy dean, he can tell u,when i raped him on our last race.......P.S, this doesnt mean i dont love u jd..........just business...
__________________
2000 f-150,superchip,mac intake,70mm mass,true duals,white faced gauges,clear corners,carbon tails,billet grill and a 200 shot of nos!!!!!!!
You can eliminate the muffler completely and install a Y-pipe for duals out the back. The cats muffle the noise quite a bit. it is not as loud as you'd expect. You can always go back and add a muffler if you want to.
That is what I have, all my cats still on, one pipe coming out of the cats and the pipe dumps out b4 the right side rear tire.
Would it be louder if I installed the 40 series Flowmaster??
__________________
2005 Ford F-150 Ext. Cab FX4 5.4L
do they make thes high flow cats for bolt on operation or is it weld in? I need to replace both my cats on left and right banks since they are bad, the couls like screaming kittens when I'm at idle. It gets really annoying.
I would assume they are welded? I've never really checked myself. If the old ones are welded then you will probably have to weld the new ones on. Dunno for sure though, I'm a breeeetard when it comes to welding stuff.
I find my stainless steel single in/ dual out exhuast, with turndowns, to have a aggresive sound when I get on the gas, but without being to loud when cruising. I have 3inch pipe from the cats back to the muffler( and the I can see from one side of the magnaflow to the other). Flows well, I think. Too well, my fuel economy went down a little. Need to get a mac air intake to balance it out.
__________________
2001 Black F-150 SC
4.2 Liter 5spd
K&N Oil and Air Filter
Magnaflow Exhuast
Working on Mac Air Intake
like you know when our engines take off atleast mine(just no muffler) takes off it doesnt sound like a v8 loud, as in kind of like when a semi jake brakes it-that kind of sound
__________________
It doesn't have the throaty V8 sound, but It does sound more agressive, especially as the RPM's grow higher. IT defiantly sounds better at higher RPM's. The dual exhuast out to the bumper sounded like the v6 was struggling to push the exhuast out, but it sounds ok now. I have tp listen to it more closely next time I take it out.
__________________
2001 Black F-150 SC
4.2 Liter 5spd
Magnaflow Exhuast
