Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-18-2004, 10:50 AM
tnm tnm is offline
tnm is starting off with a positive reputation.
Help! Plugs won't come loose!
I went to swap my plugs and wires the other day and the plugs would not come loose. Is there something I'm doing wrong? I just tried pulling them straight off. Do I need to squeeze and pull the wires or what? They absolutely refused to come loose! BTW, its a 3.0L V6 in a 98 Ranger. And can anyone give me a straight answer on which plugs to use? Its got the 100k mile plugs now. I don't know if its got the EDIS ignition or not. Thanks
  #2 (permalink)
Old 02-18-2004, 11:21 AM
Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE.
First, welcome to FTE!!!!!
Is it the plugs, or the plug wires that won't come off??
If it is the plug wires, try twisting them first to break the boot loose from the plug.
You do have EDIS ignition, so the best plugs to use are Motorcraft double platinum....
Good luck!!
  #3 (permalink)
Old 02-18-2004, 02:31 PM
tnm tnm is offline
ugh i mean plugs
Thanks for the welcome! I meant the wires won't come loose. I'll try twisting them to break them loose. And are Autolite plugs the same as Motorcraft? Also, are the Autolite wires any good? The local Advance (or Autozone) said they were the best their store sold for the Ranger. Thanks again
  #4 (permalink)
Old 02-18-2004, 05:00 PM
Well, there are different opinions on Autolite vs Motorcraft plugs,
I understand that they are both manufactured by Honeywell, a
subsidiary of Allied Signal. Allied Signal is also the parent company of Fram, and we all know how much we hate Fram oil filters!!!!!
Personally, I like to stay with the OEM manufacturer, especially on oil filters and spark plugs. I use Motorcraft in my Fords, and Bosch in my Mercedes. The previous owner of my little Ranger had installed Bosch platinums in it, and it missed like crazy until replacing them with Motorcraft double platinums. Bosch, however run great in my Mercedes!! I believe it has to do with having the correct heat range plug.
  #5 (permalink)
Old 02-23-2004, 10:40 PM
saintthomas is starting off with a positive reputation.
Re: ugh i mean plugs
Quote:
Hey there, I have a 98 Ranger and run Autolite everything. I have no trouble at all. And what Bob said about Honywell is true. However, we must remember that just becasue the same company makes them, they aren't really the same. Think of it like Coke and Dr Pepper. Both made by the same people but with different flavor. Same goes for parts. The trick is to find a product you TRUST. The truth is quality is about hte same in all OEM manufacturers. UKse what you feel confident in.
__________________
98 Ranger 3.0L
Spray in liner
UWS Bed Protectors
Dee Zee tailgate cap
Curt class III hitch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
