302 5.0 firing order
Mr. Wiz427,
I don't know the size or year of my small block Ford.
Around the starter I can make out these castings:
D3C or D3G
2J23 is horizontal above the starter mounting flange
There is also a ?DAE behind the starter on the block.
It has a 4 bolt crank pulley and a 2 bbl. carb which looks original.
Knock in freeze plugs, two I think.
Would any of this give us an indication?
Is the firing order different on the 289/302, etc.?
Thanks,
TractormanBill
D3C or D3G
Thanks,
TractormanBill
on
If it's a carbed motor and it is a 302 it will have the 15426378 firing order, if however it is a 351 it will have the 13726548 firing order. How do you tell the difference? Are the water pump holes level with the cylinder head gasket or an inch below it? Is the distributor base level with the intake gasket or an inch below it?
Welcome
Welcome to Ford Truck Enthusiast's!!! Just ask as many questions as you want or reply if you like.
There are a great bunch of guys and gals on the Forum that are very knowledgeable so use their experience. I certainly do!!!
Take care and again WELCOME!!!
Boon
P.S. I have a Korean Jindo named Dohgee. She is a white/tan and an unbelievable dog. I would love to get a Jindo puppy but the rescue websites do not have puppies that I know of.
Hello jlk and how are you?
Boon
Boon
The member is new.
Boon
James888
13
01-20-2016 02:13 PM
msb71
05-03-2005 10:11 PM
Fully_Loaded
05-16-2004 08:37 PM
