Tire size chart? - Page 3 - Ford Truck Enthusiasts Forums
Tire size chart?
  #31
Old 05-11-2004, 08:08 PM
Montana Bronco's Avatar
Montana Bronco Montana Bronco is offline
Montana Bronco is starting off with a positive reputation.
305/70/16
Will 305/70/16 Goodyear MT/R's fit without a lift ? And will they work with the optional aluminum rims (16x8) ?
  #32
Old 05-12-2004, 05:41 PM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
Quote:
Assuming you have a 4x4 F-150...
IMO, they will barely fit on the 16x8 rims but will not fit on the truck with out a 3'' lift...the Gy 305/70/16's MTRs are 33" tall, and the big ***** will prolly rip a fender up with out a lift.
This info was on the first page of this thread.
I wouldn't chance it.
  #33
Old 05-24-2004, 08:33 AM
Quote:
Originally Posted by DRT BOY
I have 2002 F-150 with the FX4 package. I want to install a 3" PA Body lift & replace my factory wheels/tires with 16x10 wheels & LT 315/75R/16 tires. If I do this will I experience any rubbing? I'm willing to do a little trimming if necessary but I don't want to crank my torsion bars.
Thanks In Advance!
According to my chart on the first page of this thread, you'll need to go with a 4'' lift to fit the 315/75r16 tires...and even then you may need to trim a bit. I would think about a narrower rim (8''-10'' will work for this size), I would stick with a 8'' - 9'' rim due to all the vibration problems I've seen with the wider rims on a F-150....but 10'' rims will work.
  #34
Old 05-24-2004, 04:01 PM
lariatrider lariatrider is offline
lariatrider is starting off with a positive reputation.
Hey to all,
I have a link that may or may not help but anyway here she goes: www.miata.net/garage/tirecalc.html
This link will help you with tire height and speedo calculations.
Ex: if you are running 265/70/17 and want to up-size enter 265/70/17 on the left hand side and enter the size you would like to go to on the right hand side. It will tell you: the old height, the new height, and the speedo difference!
Pretty neat huh?
ok well have fun.
lariatrider rides on........
  #35
Old 05-25-2004, 08:59 PM
DRT BOY DRT BOY is offline
DRT BOY is starting off with a positive reputation.
I currently have stock rims but I plan on purchasing MAXX 6 wheels by Helo size 16x10.
  #36
Old 05-31-2004, 01:53 AM
CPerry's Avatar
CPerry CPerry is offline
CPerry is starting off with a positive reputation.
Look up 10 posts. My truck has 285/75r16 tiresin the pic. I installed a 2" body lift since then though.
  #37
Old 05-31-2004, 01:05 PM
Peter Nikols Peter Nikols is offline
Peter Nikols is starting off with a positive reputation.
Hello,
Seems that it's a concencus that 33 inch is about as high as you can go. That still leaves about 6 inches of open space (between the tire and the fender) in the front and 8 in the back. I hear everyone talking about raising it even more which sounds like the exact opposite of what we are trying to achieve. Shouldn't we be lowering these trucks? That would look better, I think. Although that is a personal oppinion. Where would it rub anyway?
Thanks everyone.
  #38
Old 05-31-2004, 01:19 PM
CPerry's Avatar
Maybe 6" of space from top to bottom with 33's but less that 1" of clearance in front and less than that when the wheel is turned. That is why a lift is needed. Many people responding to this thread have 4X4's and get larger tires for better traction. Why would you want to lower a 4X4?
  #39
Old 06-07-2004, 12:59 AM
dansbrother dansbrother is offline
dansbrother is starting off with a positive reputation.
What are the benefits or disadvantages for using a larger tire. I have a 2000 4x2, and was looking to put on 265-75R16 mainly for aesthetics, because they are essentially the same price as the stock size.
So far, this thread has told me that the speedo will read the wrong speed (from the Miata link), and there is a decrease in the towing capacity. Any other drawbacks? Any other reasons to increase in size, even though it isn't that big a jump in size?
  #40
Old 06-07-2004, 09:29 AM
It will get a bit more bouncy...
You could also get 275-70R16. They are about the same height but they are a bit fatter.
  #41
Old 06-16-2004, 11:37 AM
Quote:
Originally Posted by Tenordude22
Hey, this seems like the right place to ask this question, it may have been answered before, but here we go.. I have a 98 F-150 Ext. Cab Flareside V8 2wd. I'm looking to put some 33 inch BFG All Terrain K/0's on it, now, will I have to lift it? If so, would a 3inch body lift do the trick and what would be the best lift kit to get? Would it be possible to fit them without a lift? Any help would be greatly appreciated. Thanks.
You don't have to lift it. It will fit.
If fact if you keep it under 33 in, you might be able to lower it a bit.
These trucks look good lowered. The 4x2's are easier to lower.
Don't raise it. It won't handle as well.
  #42
Old 06-16-2004, 01:38 PM
CPerry's Avatar
33" tires will NOT fit on a 2wd F150 without lift. A 3" lift will make it a tight fit and you may need to trim a little off the plastic. Read the entire page one of this thread for more info.
Peter, this person wants to put on All Terrain tires, which leads me to believe he likes the pre-runner look. 4X2 trucks may look good lowered with low profile tires and 22" rims but not big all terrain tires.
  #43
Old 06-16-2004, 01:45 PM
TAMU05's Avatar
TAMU05 TAMU05 is offline
TAMU05 is starting off with a positive reputation.
i have the bfg at's 285-75-16's (32.8x10.50) on my 98 2wd f150, had to put a 3.5 inch lift on. the biggest you can go, without a lift you can is 265-65-16's (29.6x10.4). mine handles alot better after the new suspension. check out the post i put on the first page it has all the tire sizes and lift sizes. check out my gallery i have the setup you are talking about. except a suspension instead of body lift.
  #44
Old 06-17-2004, 11:39 AM
bigmack bigmack is offline
bigmack is starting off with a positive reputation.
I have a 98 F-150 flairside Kingcab 4x4, no lift, I have been running 295.75.16's on Baha 10.16 rims for about 4 years now with no problem. This is the second set I have an got a little scrubbage but a tweek on the torshion bars cleared that up. BTW, I got 65k out of the first set BFG AT ko keeping the tire pressure at 65 psi and still had over 10k of tread left. My son is running them as we speak on his F-150.
  #45
Old 06-17-2004, 01:01 PM
Quote:
BFG All-terrains.....Can't go wrong with them!
295/75R16's.....is this a typo for 285's?
It's been a real long time since I've seen a 295/75R16 BFG At.....but I may just have my head in the sand!
Good to hear that you've had good luck with them!
4 inch lift. what tire 1jeffm 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-19-2016 08:41 PM
So many threads re: ZF5 trans swaps joegeds 1987 - 1996 F150 & Larger F-Series Trucks 3 02-10-2015 12:43 PM
302 power curve chart Milwaukee1979F150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-21-2009 12:16 AM
6" Suspension lift, Tire size?? frdf250 1999 to 2016 Super Duty 18 09-02-2009 10:45 PM
Tire Size Conversion Chart Andysutt Brakes, Steering, Suspension, Tires, & Wheels 2 01-30-2004 12:20 AM
Tags
1997, 2001, 2003, 28570r17, chart, f150, ford, lariat, lifted, size, sizes, stock, supercrew, tire, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
