Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2004, 11:17 PM
jamessl1 is starting off with a positive reputation.
steering colum noise 79f2504x4manual
I am hearing an annoying creeking,shuddering, sound from my steering colum when I encounter bumps(constantly). I imagine the bushings or bearings are worn. Seems to be getting worse. Has anyone out there rebuilt one? Where can I get replacement bushings or bearings. I hate to take it apart and not have parts on hand, it is my only form of transportation at this time. Could I possibly get by with dissassembly and some good lubricant. Any input greatly appreciated.
  #2 (permalink)
Old 02-18-2004, 12:11 AM
77crew is starting off with a positive reputation.
I thought they were supposed to do that. both of mine have done that for as long as I can remember. It's annoying, but I like to think that it adds character I used to wonder why the steering wheel bounced when I went around left hand turns only to find out that my shock had rusted through in the back and the entire wheel was boucing off the ground. Most of the noise from my steering actually comes from the plasic steering shaft cover rubbing against the steering wheel. It certainly warrants looking into, but don't dismiss the idea that it might be something as simple as a strategic shot of WD40. Does your steering have any abnormal play? Also make sure the screws are tight where the cover meets the dashboard and take the ashtray out just to be sure. There is a lot of metal to resonate on that dash, and it can make it difficult to pinpoint a sounds location. good luck
  #3 (permalink)
Old 02-18-2004, 11:07 AM
oldhalftons's Avatar
oldhalftons has a good reputation on FTE. oldhalftons has a good reputation on FTE. oldhalftons has a good reputation on FTE.
As soon as summer hits and its above 80 degrees, my 79 steering column squeaks like a tortured guinnea pig
It's done it for as long as I've onwed the truck. It goes away as soon as the temp falls.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
