Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2004, 05:06 PM
isaz is starting off with a positive reputation.
Crew Cab Gas Tank
I have a tank of a 1979 F250CrewCab 4x4 Does anybody know if the main tank (side of the frame)is the same tank of a regular cab.
My tank has a hole in one side and a 1"crack on the side where it
rests on the side of the frame.Or should i just repair the tank i have now.
Thanks for all the help...
  #2 (permalink)
Old 02-17-2004, 09:25 PM
bpete is starting off with a positive reputation.
I think technically they will not interchange 100% but you could make one work you will probably need the straps and brackets if possible and there may be some evaporative emissions you could cap off if you don't need & the neck size and location may be slightly different. good Luck
  #3 (permalink)
Old 02-17-2004, 11:44 PM
Mil1ion is starting off with a positive reputation.
Just so you
The Rear Tank is considered the Main Tank .
The Auxillary tank is the Front side tank
  #4 (permalink)
Old 02-17-2004, 11:52 PM
77crew is starting off with a positive reputation.
I have a 77350 crew 2wd and I once compared it to the tank on a 78 150. They appeared visually the same. so I would guess that any difference would be minimal.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
