Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2004, 11:40 AM
tiredofexplorer is starting off with a positive reputation.
Angry Engine missing
I have a 98 Explorer 4.0. It started missing a couple of days ago. Pulled plug wires and found that number 2 wasnt firing. I went ahead and changed plugs and wires. Started and have the same problem. I checked and I am getting fire to the plug. So any help would be appreciated.
Thanks
  #2 (permalink)
Old 02-17-2004, 12:29 PM
mrshorty is starting off with a positive reputation.
Is the fuel injector firing? How's compression?
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 02-17-2004, 06:22 PM
GrayRanger4x4's Avatar
GrayRanger4x4 is gaining momentum as a positive member of FTE. GrayRanger4x4 is gaining momentum as a positive member of FTE.
It might be a coil pack going bad.if there is no fire to that plug.JMO
__________________
Only two defining forces have ever offered to die for you,
Jesus Christ and the American G. I.
One died for your soul;
The other for your freedom.
Many seem to have forgotten both of them.
Member of the Georgia Chapter
  #4 (permalink)
Old 02-18-2004, 07:49 AM
Thanks! But I am getting spark to the plug. I have not done a compression check or checked the injector, like everyone I was hoping for an easy fix.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
