Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-17-2004, 09:41 AM
Santoken Santoken is offline
Garage is empty, add now
Santoken is starting off with a positive reputation.
Unhappy Engine Identification
A friend of mine just bought a '79 F150 4x4. When he purchased it, the previouse owner claimed he did a motor swap to a 460. It's quite a nice truck, and runs great. The other day, while under it checking it all out, we stumbled upon this 'adapter' that is between/over top of the timing cover. This adapter is approx. 2" thick and at the bottom of it is two ports that are plugged. This adapter/plate is directly between the balancer and the timing cover.
We have talked to others and have heard everything from it being a marine engine, an industrial engine, an engine oil cooler with a crankshaft driven pump inside, etc.
While I'm not the most familier with big blocks, I'm at a bit of a loss. Can someone help us identify this engine and what that added cover is?
Kent
  #2 (permalink)
Old 02-17-2004, 01:31 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Post the numbers that are cast into the block & heads.
Plus, Photos ?
  #3 (permalink)
Old 02-17-2004, 08:53 PM
greenhighboy's Avatar
greenhighboy greenhighboy is offline
greenhighboy is starting off with a positive reputation.
Some 68-69 429's had a crank driven powersteering pump. That sounds like what you are describing.
Tags
370, 385, 429, 460, big, block, engine, ford, identification, identify, industrial, location, numbers, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
