Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2004, 10:36 AM
drdemo35 is starting off with a positive reputation.
1979 460 Upgrade, parts matching/interchanges
I have a 1979 F250 Supercab 2wd with a 460. I plan to purchase some used heads to have rebuilt for this truck. I am also looking to buy and install an Edelbrock 2166 or 3766 intake, 1407 manual choke or 1411 electric choke carb, headers, and mufflers.
Some of these may be purchased used(the heads will be). What do I need to look out for as far as the differences in the many years of 460s? Would it be a good idea to replace the lifters while I'm in this far without doing any machine work? I have noticed some headers listed as "except supercab", whats the difference there? Knowing that keeping costs down, what is a good choice for headers and mufflers? I'd like some good flow with a deep tone but nothing real loud and none of the "flapping" sound I hear on some trucks during acceleration. Any pros/cons of exhaust crossover?(it seems to be it smoothes out the sound)
Also, the 2wd is an easy stick in wet grass and leaves. Is the heavy duty rear end "full floater" and what could be used as far as a locker or other to give it posi traction.(don't forget budget)
Any ideas? Tips? Suggestions? What worked for you?
Thanks.
  #2 (permalink)
Old 02-17-2004, 12:54 PM
WTAGAS is starting off with a positive reputation.
It all depends on what you want your truck to do and how much you want to spend. I'll figure you just want to stay somewhat stock and have a modest budget.
1st. you (if it's a '79) have a external balanced motor and probably running a 8 to 1 compression ratio with D3VE heads which if I'm not misstaken is about 210 horsepower from the books I've read.
So we'll look at the heads first, there are several heads out there. The stock usage D3VE heads with alittle work like grinding out the thermactor bumps and alittle clean up will work fine. If you want more flow you'll need to find a pair of D2OE (PC heads) or a set of D0OE or D0VE (CJ/ SCJ heads), although your waisting money if your staying close to stock, they can get pricey. Have the head shop replace the vavle guides with new ones (don't have them knurled) and install postive valve seals on intake and exhaust.
If you are considering a larger than stock camshaft, the D3VE heads will need to be retro fitted with a kit that Crane makes to make the rockers adjustable or have the pedistal mounts machined. The others have screw in studs and pushrod guide plates.
As far as a manifold choice the 2166 will help meet emision standards and give you good torque were the 3766 is for higher horsepower in the higher rpm range.
The carb choice of a 750 is larger than one needs for a stock or close to stock operation, a 650 would do fine.
Do'nt scrimp on the headers and exhaust system, get the exhaust out the best you can, I'd suggest a minimum of a duel 2 1/2" ID. system. The crossover helps equalize the back pressures from bank to bank, a good idea.
Mandatory items are a pre '69 timing set putting the cam at straight up position instead of the retarded position it's in to meet emission standards and a MSD or alike ignition because most of your driving/crusing is under 3,000 rpm.
The biggest thing you could do is raise the compression ratio to 9.5 to 1 and still run 87 octane gas, I'm at 10.5 and still run 87 without detination.
How much do you want to spend?
Ford's don't have a posi (chevy's do), Ford's have limited slip, check these guys out.
http://www.drivetrain.com/index.html
Hope this helps.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
