02-17-2004, 11:58 PM
The main difference is the valves and valve seats are made out of Inconnel.
The pistons are hypereutectic which is a high heat resistant aluminum, silica and several other material alloy in all the Navistar diesels, but the turbo ones have bigger wrist pins.
The compression is actually a little lower on the turbo motors as well to make room for all that extra air the turbo blows in there.
I spoke with a tech support guy at ATS about the different components and were they worth the money difference as the Inconnel valves are high dollar items.
His reply was that they had thousands of their turbo's out there on completely stock NA 6.9 and 7.3 IDI motors running boat loads of miles without problems.
Most of the work you will need done other than disassembly and reassembly will have to be done by a machine shop. I would talk to several different shops and get input from them on how they feel. I would also talk to several garages to see who they get to do their machine work on diesel motors to figure out which machine shops to talk to first.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
