Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2004, 09:41 PM
Fordzilla_4X4_King is starting off with a positive reputation.
EFI gas engine to 7.3L swap?
right now i havea 1987 f-250 4x4 ex cab xlt lariat with a 7.3L desiel that is 1989 about the only good thing on it is the engine tranny/transfer case it still runs and drives good but body is rough
i have found a 1987 f-250 4 door 4x4 xlt lariat body is in a flawless condition with good paint the truck also as exalent intrior but the EFI factory motor is blown up and the tranny screwed
so how hard would it be to swap these to motors and trannys?
  #2 (permalink)
Old 02-16-2004, 10:18 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Swap the complete fuel systems.
Swap the insturment panels.
Swap the engine compartment wiring, including the battery system.
Swap the motors and trannys.
Depending on what axles and gears are under the EFI you may have to swap the axles.
The gasser may have a 9" Ford differential, no big hub in the center of the wheel.
Probably swap the front springs as well.
There will probably be some wiring from the dash to the engine compartment that may not be there as well. But then again it may, I am not sure if the main wiring harness was the same or not.
Also check the frame rail sizes (thickness) to make sure it is not a light duty 250 frame.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
