Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-16-2004, 07:30 PM
danny waterman danny waterman is offline
Garage is empty, add now
danny waterman is starting off with a positive reputation.
1985 2.3liter
I put new rings in my 2.3 liter engine, now i have a problem of sut like substance coming out of the tail pipe, also losing oil, I have to put approxiamately 2 liters of oil a week in. Can someone help me
  #2 (permalink)
Old 02-17-2004, 12:16 AM
Lone_Ranger01 Lone_Ranger01 is offline
Lone_Ranger01 is starting off with a positive reputation.
Who installed the rings? Do you notice and smoke coming out the exhaust? It sounds like your burning oil which would be why you've got soot coming out of tail pipe and why your losing oil? Pull out the dipstick and smell the oil, does it smell like gas?
__________________
http://www.ford-trucks.com/user_gall...&photoid=35316
2001 2.3 I4 Ranger,5-spd, XLT Stepside, Reg Cab
Loud pipes save lives!
  #3 (permalink)
Old 02-17-2004, 05:08 AM
belinda belinda is offline
belinda is starting off with a positive reputation.
miller-ray@sbcglobal.net
1999 F-250 Superduty 4X4 7.3L Diesel
My problem is that I can be driving my truck and then the engine just dies and the I can't start it again. But, if I let it sit a little while. It will start and run again. I have gotten it check for codes and there is no codes present. I have changed the fuel filter and check the fuel pressure and pump. All good, but still have this problem!!! PLEASE HELP!!!!
  #4 (permalink)
Old 02-17-2004, 12:37 PM
It definetely sounds like a problem with your new rings. Do a compression check and that should give you some clues as to whether its a ring related problem or not.
__________________
  #5 (permalink)
Old 02-18-2004, 07:27 PM
built4wheelin's Avatar
built4wheelin built4wheelin is offline
built4wheelin is starting off with a positive reputation.
did you hone the cylinders???
what type of rings did you install? crome-moly?
align the end gaps properly?
install the rings right side up?
check your end gap? what was it?
__________________
1990 bronco d60 detroit/14b detroit 5.13 39's
1968 bronco spooled 4.10 33's
2004 superduty powerstroke hauler
http://built4crawlin.tripod.com/
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
