Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2004, 06:26 PM
johnrebbb is starting off with a positive reputation.
Question Where's the relay???
Howdy again guys,
I really could use bailing out right about now. I need to find the darn fuel pump relay! It's sticking on and draining the battery. What's more, I suspect it's going out all together since the van dies while going down the road on occasion. My beast is an '87 Clubwagon with 5.0l and AOD tranny.
Thanks in advance Fellas,
-John R.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-16-2004, 07:12 PM
94van is starting off with a positive reputation.
You check behind the passenger's side kick panel?
__________________
'94 E-150 Conversion Van 4.9 / C-6
'89 Mustang 5.0 - Original Owner
'06 Mustang DeLuxe V-6
  #3 (permalink)
Old 02-16-2004, 08:03 PM
Not yet. I think I've looked everywhere else though. Nothing looks guilty. Autozone's sight said it was on the passenger fenderwell. If it is, I didn't see anthing that looked like a relay there. I'll try behind the panel next I guess.
Thanks.
-John R.
  #4 (permalink)
Old 02-16-2004, 09:36 PM
pfogle's Avatar
Village Idiot
pfogle is gaining momentum as a positive member of FTE.
Look under the hood, there may be a Power Distribution box kind of under the brake master cylinder. In my 1992 that is where it is, and in my dad's '88 as well.
__________________
1992 E150, 351, 1 ton E4OD (RIP)
Courtesy of my WIFE: "Why do they call it 'scruff' when it's more like mini-daggers?"
  #5 (permalink)
Old 02-17-2004, 07:54 PM
Knightmayre's Avatar
Knightmayre is starting off with a positive reputation.
Mine is on the inner passenger fender, right next to the battery.
There are a couple of other relays there, but I haven't worked out what they're for yet.
__________________
88 E150 Conversion
302 EFI, uprated inj, home-made RamAir, full duals & no cat
______________________________
http://www.ncfto.org
  #6 (permalink)
Old 02-18-2004, 05:20 AM
Howdy again fellas,
I found it! The inertia switch is on the passenger kick panel. The fuel pump relay is above that under the dash a bit. Initially I thought the EEC power relay was the one, but the wire colors were wrong. I also think I've finally found my 1st worthless Hayneys manual! Chilton saved my butt!
Thanks for the input guys!!!
-John R.
  #7 (permalink)
Old 02-18-2004, 11:43 AM
blue_mule's Avatar
blue_mule is starting off with a positive reputation.
"johnrebbb said" "I also think I've finally found my 1st worthless Hayneys manual! Chilton saved my butt!"
John, I bet i have 2 of the same Haynes book.... Cant find any good info for a 91 Clubwagon in it.
__________________
"let us Bray'
Blue Mule is a 1991 E150 Clubwagon XLT 351, E4OD
  #8 (permalink)
Old 02-19-2004, 04:08 AM
Haynes has an update chapter in this one for '87 an on. It's close to pointless. Even thier wiring diagram's wrong. I've got The Helms manuals and the Chilton for my '87 Clubwagon. Thank God I did this time. I broke my right arm and took my '90 F-150 w/M5OD tranny out of service. This darn van is really needed now!
-John R.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
