Limited slip [positraction] 2000 F150 4x4 - Ford Truck Enthusiasts Forums
Old 02-16-2004, 04:56 PM
mikeB1 mikeB1 is offline
mikeB1 is starting off with a positive reputation.
Witch is a better system for regular driving in upstate NY? We are talking about a lot of snow in the Winter. A lot of mud in the Spring and late Fall. The systems I am looking at are the clutch pack system. and the cone system. I drive sixty miles a day or more mostly highway with some off road tossed in for fun.
Old 02-16-2004, 09:45 PM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
The Ford setup is called Trak Lok and GM's version is called positraction.
It really comes down to your preferences and knowing what type of settup your driving.
A open rearend is alot more forgiving on ice, especially if you just stomp on the gas, just the one wheel will spin, and you wont get any fishtailing, where as a track lock will lock both wheels up and will cause the rearend to fishtail.
You can often get started better in winter conditions with a LS rear end in straight lines, but accelerating around icy corners is really dangerous as the rearend will come out and around you.
A LS and 4x4 makes a great combo for the weekend wheeler, as they are very streetable units, and are also very effective on mild to medium trails. For the hard core stuff, lockers are the only way to go.
It really comes down to how well you know how to drive in winter conditions with a LS, for example dont accellerate around corners, and dont mash the pedal to the floor on ice.
Of course this all changes if you want to whip cookies in the Walmart parking lot.
You can really whip mad cookies with a LS.
V-drive 4WD Tom 1968-2013 Full Size Vans 10 11-18-2014 11:29 AM
Cooling System RobbD Expedition & Navigator 1 11-22-2013 07:55 PM
Gibson exhaust, 06 screw, 5.4 Mustangtoby2001 Exhaust Systems 1 04-18-2010 10:44 PM
hydroboost brake pros and cons 59flatbedford 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-15-2007 12:04 PM
4/5 inch exhaust system louder? westladog 1999 - 2003 7.3L Power Stroke Diesel 30 03-06-2006 11:30 PM
Tags
2000, 2003, 4x4, f150, ford, good, limited, locker, mud, posi, positraction, ranger, setup, slip, traction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
