Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2004, 04:18 PM
akmud is starting off with a positive reputation.
Vacum/idle?
I have a '95 Bronco with a 351W with speed density. I bored .030, new rv cam, gasket match. Ever since the rebuild I have had problems with the idle. I used a Snap-On scan tool to find any codes and found none. I thought I might have a vacum leak so I used propane, water, starter fluid and checked every vacum line with a hand held vacum pump and no vacum leak to be found. I put a vacum gauge on it and it tells me I have a vacum leak. Someone told me I may have got a to egressive cam for the computer for the speed density system to compensate for. Can someone clear this up for me? I don't have the cam info here at the house. It it is needed I will put it on next time.
  #2 (permalink)
Old 02-16-2004, 04:21 PM
87MarkVIILSC is starting off with a positive reputation.
with that hot cam you might need to add a bigger vacuum canister or even a vacuum pump off a diesel.
__________________
1987 Lincoln Mark VII LSC (daily driver)
1995 Ford Thunderbird LX 4.6
1986 Ford F-150 XLT Lariat,351w 4v
  #3 (permalink)
Old 02-16-2004, 04:34 PM
Which would be better the canister or the pump? A vacum pump off a dieseal? I have never heard of that!!!! Which one do I get it out of and is it a direct hook up?
  #4 (permalink)
Old 02-16-2004, 05:52 PM
fordeverpower's Avatar
fordeverpower is starting off with a positive reputation.
i thought rv cams are practically stock and if anything your engine should have more vaccum.
__________________
Matt
79 f150 390 4x4 c6 RIP
78 F100 390 2wd c6
78 F150 351m 4x4 c6
  #5 (permalink)
Old 02-16-2004, 06:58 PM
That's the problem I think the place I got the cam sent me the wrong one.
  #6 (permalink)
Old 02-16-2004, 07:12 PM
call them and check your spec card again if you have it.
__________________
Matt
78 F100 390 2wd c6
78 F150 351m 4x4 c6
  #7 (permalink)
Old 02-16-2004, 09:07 PM
78fordman's Avatar
78fordman is starting off with a positive reputation.
You would know if you got that big of a cam. Usually when the cam is having vacume problems, it will lope at idle, atleast in my expiriences, but the efi might be compensating. That could be your idle problem too.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #8 (permalink)
Old 02-16-2004, 09:43 PM
I did call and they told me that their computer listed the cam as the one I wanted.
I do have a slight "lope" and I do think that is what is causing my vacum problem.
  #9 (permalink)
Old 02-17-2004, 08:48 AM
jwtaylor is starting off with a positive reputation.
What is the lobe seperation of the camshaft?
  #10 (permalink)
Old 02-17-2004, 10:21 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
On some engines it's not uncommon to get a vacuum leak under the intake manifold.Check inital timing. What is the vacuum gauge doing? Does it run OK above idle?
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #11 (permalink)
Old 02-17-2004, 11:11 PM
The needle on the guage is towards the bottom of the guage. Like I said the guage says that its got a pretty bad vacum leake. The way the guage reads you would think that the leak would be easy to find.
  #12 (permalink)
Old 02-17-2004, 11:13 PM
sorry did not answer the whole question. Above idle it's better but I don't think it's where it needs to be.
Oh yeah, sorry for not paying attention to how I spell gauge.
  #13 (permalink)
Old 02-18-2004, 01:33 PM
rainbowATF is starting off with a positive reputation.
The actual vacuum reading at idle and the behavior of the needle; and at opening of throttle would be more helpful in diagnosing a problem.
  #14 (permalink)
Old 02-19-2004, 12:54 AM
I will get it this weekend and post it. dont forget about till then
  #15 (permalink)
Old 02-19-2004, 01:21 AM
DW2455's Avatar
DW2455 is starting off with a positive reputation.
it would help alot to know that actual vac. readings and the cam specs. but just for the record, there are very few after market cams that will run with speed density system with out causing problems. DW
__________________
MY Web site have A L@@K
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
