Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-16-2004, 09:14 AM
WhyBlue? is starting off with a positive reputation.
17" Wheels for 76 F-100 2WD??
Anyone happen to be running 17" wheels?? I bought a 76 F-100 2WD a few months ago with aftermarket aluminum wheels(15"). But I really don't like the looks of the wheels and the tires aren't that great!! Anyway, I found some pretty good deals on some 17" factory wheels from newer Dodge Rams or 2004 Durango's!! The tire diameter is about 1/2" to 1" bigger then what I currently have!! Any thoughts or ideas??
Thanks,
Rich
  #2 (permalink)
Old 02-16-2004, 09:40 AM
73Custom is starting off with a positive reputation.
I don't think the bolt pattern is the same. Ford factory wheels will fit up to '96 F150, the lightnings had some good looking big wheels....
Marty
__________________
Cleverly Disguised as a Responsible Adult
  #3 (permalink)
Old 02-16-2004, 03:53 PM
FordPickup460's Avatar
FordPickup460 has a great reputation on FTE. FordPickup460 has a great reputation on FTE. FordPickup460 has a great reputation on FTE. FordPickup460 has a great reputation on FTE. FordPickup460 has a great reputation on FTE.
Go to some wheel/tire shops and ask them, they should have some stuff there, and they should also have catalogs to order you stuff.
  #4 (permalink)
Old 02-16-2004, 09:06 PM
IAM.CA is starting off with a positive reputation.
The new Rams still have the 5 on 5.5 bolt pattern, so those rims should bolt right on. The Durangos are a 6 lug, are they not?
  #5 (permalink)
Old 02-16-2004, 10:55 PM
77lowrider's Avatar
77lowrider is starting off with a positive reputation.
While the new(& old) Rams have the same bolt pattern, the wheels require a flat mounting surface. By this I mean, the dust cap on the fords hit the back of the rim. If u look at the dodge's, the disc is outermost, and everything is flush to it. The locking nut is internal....etc. I have a friend with the Ram 20's, and I tried to fit them on mine. It just dont work. You would need some perty healty spacers to make it work, then your wheels would be out too far.
__________________
My karma ran over my dogma
  #6 (permalink)
Old 02-17-2004, 12:49 AM
LxMan1's Avatar
LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold
The new Dodge has a 5x139mm bolt pattern.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 02-17-2004, 01:20 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
Check with the suspension tires and wheel forum.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #8 (permalink)
Old 02-17-2004, 12:46 PM
So to recap...
The Dodge's have the same bolt pattern. The 2004 Durango now has 5 X 5 1/2 pattern. But the aluminum wheels won't work because the dust cap sticks out too far?? Then the chrome wheels should work as long as the hole in center is big enough because the center cap is removable?? So until someone comes up with more this is what I will be working with!! Thanks for all the info!!
Rich
  #9 (permalink)
Old 02-17-2004, 01:44 PM
79_effie is starting off with a positive reputation.
If you want chrome wheels, you might consider some Cragar wheels. I am going to buy some 17's from them eventually and they come in 5X5.5 and I know at least 2 different backspacings.
__________________
--Scott
1979 F100 Flareside "Under Constuction"
2004 F150 XLT "Scab" 4X4 5.4L
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
