Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 09:46 PM
jimcope is starting off with a positive reputation.
Thumbs down Dash Lights
OK, I have been reading the threads about dash lights and today I tried to get mine a little brighter but ended up with one side going dark all together. The back of the dash has a film like a printed circut board any ideas on how I get the lights working when they are out on only one side? Help
  #2 (permalink)
Old 02-16-2004, 12:56 AM
Txquadhunter24's Avatar
Txquadhunter24 is starting off with a positive reputation.
sounds like it's time for ya to hit the wrecking yard looking for a new gauge cluster
  #3 (permalink)
Old 02-16-2004, 01:05 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
If the flex circuit is ok and the plastic is not crumbling then all you have to do is clean up all the contact points, contacts, bulb holders etc. Onece you have everything clean smear a little silicone dielectric compound on all of the contact points before you put it all back together. Use new TESTED bulbs when you assemble it also.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #4 (permalink)
Old 02-16-2004, 07:44 AM
Dash Lights
Is the flex circut repairable? If so how do you do it? I think I may have a broken circut.
  #5 (permalink)
Old 02-16-2004, 08:01 AM
Torque1st's Avatar
Posting Legend
If you have a broken circuit it is repairable with special materials but it is easier to get a new flex circuit from the salvage yard. Those things are fairly tough tho. A problem is more likely in a bad contact either at the wire plug or at the bulb holder.
__________________
  #6 (permalink)
Old 02-16-2004, 08:22 AM
73Custom is starting off with a positive reputation.
My flex circuit had a crack through one of the 'wires'. So I cleaned it up good and soldered the crack closed, then painted over it with a plastic coating. It has worked for over 3 years and was an easy fix - but I solder every day, lots of practice.
Marty
__________________
Cleverly Disguised as a Responsible Adult
  #7 (permalink)
Old 02-16-2004, 08:29 AM
19gator55 is starting off with a positive reputation.
Radio Shack has a silver solder pen that can sometimes be used to fix traces on circuit boards also. I believe it was 3 or 4 dollars. I have used them on regular PCB's with success. You might want to try that.
__________________
1977 F-350-4x2 Ranger XLT
Super Camper Special 460 -C6
List Mod's or Equip In Gallery.
FTE
  #8 (permalink)
Old 02-17-2004, 04:49 PM
Thanks
Thanks for all the great ideas guys. I have not had time to try any of them but will let you know how it turns out
  #9 (permalink)
Old 02-17-2004, 08:18 PM
Mil1ion is starting off with a positive reputation.
There are also *printed circuit* boards available in the classifieds if you don't want to go through the repair thing.
  #10 (permalink)
Old 02-18-2004, 12:37 AM
bassdude is starting off with a positive reputation.
around here you can get a gage cluster from the pull it your self place for like $13. thats what i did for my 76. seems like the cheapest and easiest way to go. you can use ones out of vans all the way up to 86 i think. i got one out of an 85 van, it looks like brand new.
  #11 (permalink)
Old 02-18-2004, 10:47 AM
quadrazer is starting off with a positive reputation.
Thumbs up
I had the same problem with my dash lights not working. It turned out it was only the contacts were dirty where the bulb turns in against the circuit board. While I was in there, I also pulled the blue/green covers off the bulbs and then reassemled everything. Wow, what a difference! Hope it works for you!
__________________
My Trucks
1978 Ford F-350 S/Cab T/S
1998 Eddie Bauer Explorer
1995 Limited Explorer
  #12 (permalink)
Old 02-18-2004, 11:41 AM
wezol5484's Avatar
wezol5484 is starting off with a positive reputation.
What you can also try is on the black housing that holds the bulb, there are two copper arms that stick out and those are what touches the contact points on the circuit board when u twist them in. Mine were kinda flat and the connection was kinda loose so i just bent those arms out a little and it made the connection tighter. Hope that makes sense.
__________________
give blood....play hockey
  #13 (permalink)
Old 02-18-2004, 07:02 PM
Fixed Dash Lights
OK, I tried a little of everybodys advice except I did not have to repair cracks in the circut. I have them working again. Thanks to everybody for all the help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
