Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 09:28 PM
suckmykiss is starting off with a positive reputation.
1991 F250 Stalling when warm
1991 EFI F250 W/460...once I'm at operating temp, when I come to a stop the truck kills as though it was turned off. There is no warning (sputtering ect) prior. If Im Im the highway, I may feel one slight surge, and I know at that point, the next time I come to a stop it is going to stall. The truck then will crank reasonably consistant, but will not start. I have to wait about 30 min. before it will start, but then will stall after a few miles of driving.
About a week prior to all these stalling problems, I over heated a number of times. I found a leaking hose and fixed it. Added back the antifreeze.After doing so no more over heating , but did have a stuck thermostat (had no interior heat for about one hour of driving, Temp gage fluctuated up and down But then it started to work, the heat I mean. The gauge stoped fluctuating also)
The reason I mentioned all that is because My stalling problem started after all that occuring.
This couldnt have began to happen at a worse time, Im in construction and things have slowed down ( work and thus cash flow) This truck has been reliable for darn near 7 years up until now.. so I cant complain... but just the same "she's" got to get fixed asap!!
I would Greatly Appreciate advice on where to start in correcting this problem
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
