02-16-2004, 06:35 PM
You're going to need the output shaft for a 4X4.
and the corresponding rear housing to bolt on a transfer case.
The output shaft replacement MAY require the internals of the trans to be removed, then all reinstalled. I know C6 and AOD require stripdown to replace the tailshaft.
I'd estimate 2-4 hours labor at a good shop. IMHO
Depending on your knowledge level, you could do this yourself.
Look fo ATSG service manual, JCW and others sell them.
Just wait, someone else may have a clearer answer!
__________________
"Why would Ford put a six in that beast?"
