02-15-2004, 09:26 PM
all alone in the world
you will need the pump, brackets, and pulleys from a donor truck with the same motor as yours. you will need a power steering gear box, and column from a truck, 73-79 gearbox will work, column must be from 78-79 to fit properly. when you get everything just un bolt the old parts and bolt the new stuff on.
__________________
jim
underated and overworked.
