Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 06:08 PM
COBRAjrb's Avatar
COBRAjrb is starting off with a positive reputation.
Question 5.4L how much hp?
hi im wondering how much hp a stock 5.4L triton v8 has? thanks
  #2 (permalink)
Old 02-15-2004, 07:26 PM
openclasspro is starting off with a positive reputation.
2000-up
260hp
350 ft lbs tq
pre 2000
235 hp
  #3 (permalink)
Old 02-16-2004, 02:38 AM
markking77 is starting off with a positive reputation.
I thought the change from 230 to 260 was in 1998 or 1998
Searched and found this thread http://www.ford-trucks.com/forums/sh...252Bhorsepower
  #4 (permalink)
Old 02-16-2004, 06:05 AM
maybe 99?- i know the performance improved heads was what changed the rating
  #5 (permalink)
Old 02-16-2004, 01:33 PM
kspilkinton's Avatar
97-03 250LD/7700 Guru
kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE.
1999 was the cross over year.... some products had the PI heads, some didn't. Had a thread in the '97 - '03 section about a guy looking for a 250LD. The guy looked at several '99's. Some had PI heads, some didn't. The head is stamped "PI" up on the forward end. The story I recall reading said that either the Expy/Excursion got the PI's from day one or the trucks did.... I'm guessing that you'll have to look for the "PI" to make sure. The vehicles also had a change in the intakes. Some of the intakes were composite, some had a "plastic" upper.
-Kerry
  #6 (permalink)
Old 02-16-2004, 03:40 PM
CPerry's Avatar
CPerry is starting off with a positive reputation.
1999 F150's all got the PI heads and the F250 LD trucks didn't all get them until 2000.
According to my Ford owner's manual, the 1999 F150 5.4 only has 250 HP and 345 lb. ft. torque instead of 260 HP and 350 lb. ft. torque that Ford lists the 2000 - 2003 5.4's at.
__________________
1999 F150 XLT 4x4 super-cab,
4.6L auto tow package
Flowmaster 50 series,
Superchip 1715 Microtuner
Cold air intake
4.10 Gears LS
2 inch Lift
Bilstein shocks
  #7 (permalink)
Old 02-17-2004, 11:55 PM
Well that's odd, Ford didn't build a 2000 F250LD. Perhaps you're thinking superduty, which would make sense.
I recall the numbers you refer to in the van version of the 5.4, but never the truck line.
-Kerry
  #8 (permalink)
Old 02-18-2004, 02:12 AM
CPerry's Avatar
Your right, I meant Super Duty not Light Duty F250
__________________
Cold air intake
4.10 Gears LS
2 inch Lift
Bilstein shocks
  #9 (permalink)
Old 02-18-2004, 12:30 PM
LxMan1's Avatar
LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold
That truck was the F150 7700.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 02-19-2004, 10:27 PM
I know, Lx. I own one.
-Kerry
  #11 (permalink)
Old 02-20-2004, 08:44 PM
LxMan1's Avatar
Why by golly you do!! How do they ride compared to a regular F150. My OffRoad 4x4 is pretty stiff and slightly bouncy, but not uncomfortable. The 2000 F250 SuperDuty 2wd at work rides terrible. No drinking out of a glass unless you want to wear it!
Jimmy
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #12 (permalink)
Old 02-21-2004, 12:03 AM
Well, Jimmy, it rides pretty darned rough. It has the stiffer spring rates, and I upgraded to 'E' load rated tires which compound the "jolt" that much more. It was so stiff I now have a "spare" exhaust system in my yard. I ended up having a friend weld a straight pipe off the y. The new set-up exits in front of the tire ala '97-'98 models. I did that 'cause the muffler and exhaust pretty much ripped off from the sway and weight. No more dual custom exhaust. I'd be wasting my money.
My parents will probably bring their '02 FX4 S'crew out to my neck of the woods this year, so I'll have another factory Ford 1/2 ton suspension to gauge it off of. My buddy's '02 4x4 RAM 1500 rides like a cushion on our rough road and the wife's Focus handles the potholes better than this thing.
I wouldn't trade it for anything, though. It can out tow and haul that RAM. It puts the fear into my friend with the Tundra, and my Mis-guided Chevy friend has to make the standard stupid excuses when I ask if he can put a ton in his bed and not have his truck's rear sag.
Edit: Forgot to add, you put a decent load in the bed (over 500 lbs) and the truck actually rides better. My '82 did the same thing.
-Kerry
  #13 (permalink)
Old 02-21-2004, 02:16 PM
LxMan1's Avatar
That's kinda what I thought. Good for hauling, bad for riding and parts bolted under the truck.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
