P1443 - EVAP Control System Canister Purge Valve (Mechanical) Malfunction
P1270 - Engine RPM/Vehicle Speed Limiter
P0401 - EGR Flow Insufficient Detected
P1701 - ?? Not a PCM code; it might be a tranny code or something.
If you are looking for information on how to address the P1443 and P0401 codes (and DTCs in general) you will find it in the
3.0L V6 Technical Info & Tips Sticky Thread located at the top of this forum. Look under the "Components & Sensors" heading. The P0401 code is probably your DPFE sensor.
As for the code P1270, it just means you went too fast or over-revved the engine. Your 3.0L engine, by virtue of the PCM's program, has both a speed and a RPM governor built in. Just erase the code and slow down.
