Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-01-2005, 09:55 PM
larry schultz is starting off with a positive reputation.
I had the same thing on mine dealer found the throtel senser lecking oil
  #17 (permalink)
Old 03-02-2005, 12:05 AM
SBV45's Avatar
SBV45 is starting off with a positive reputation.
The throttle sensor leaking oil? Are you kidding me? Who told you that? The thing you step on the floor to go faster is actually an electronic device connected to the PCM that tells the PCM that the carbon based unit wants to go faster. The accelerator pedal position (APP) sensor is a three-track potentiometer that is used to calculate fuel quantity. The sensor receives VREF voltage from the powertrain control module (PCM) and provides a variable voltage signal directly proportional to the accelerator pedal position. No oil involved! You need a new dealer!
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #18 (permalink)
Old 03-02-2005, 12:34 AM
Choctaw Bob's Avatar
Choctaw Bob is starting off with a positive reputation.
Quote:
Welcome Larry. SBV45 is a computer genius that gets frustrated with the dealers blowing smoke up our skirts. He is accurate. The only oil on the throttle body is some that gets in the intake from the pcv valve when the turbo pressurizes the crankcase. We all have some oil residue in the intake track. It is normal.
__________________
03 6.0 SC Short bed 2WD Auto
Preditor, Gages, K & N FIPK
  #19 (permalink)
Old 03-02-2005, 08:47 AM
SBV45's Avatar
Thanks Bob, I didn't mean to sound like I was venting at Larry. I'm not. It irritates me when people who should know better, make up bs to customers.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
